Hi,
I have just purchesed a RB25DET R32 4door from japan with a HKS GT2835R turbo kit , high mounted with 38mm ex gate,GARAGE SAURAS remap ecu,480cc injectors (nismo), AFM removed ,metal nismo headgasket, step 1 tomei cams with adj cam gears from hks.
now,
bad news.. turbo is giving way apprently the auction report says.. it says "TURBINE OIL LEAK" .... I am not sure what they mean, but im guessing oil seals?..
I am tossing up to get a GCG hiflow on the standard r34 turbo i can get for dirt cheap?
Does anyone have dyno graph of the GCGhiflow on the RB25 ? and one with the 2835R HKS ?
i will be using it for drift/street purpose so i wanna compare midrange power (@4500rpm ) on 1.3bar atleast.
what is the "max power" average on these GCG turbos? and HKS 2835R?
im sure you know my situation and questions, as my turbo is probably blowing smoke like a c**t ( pictures indicate rear bar really smokey from high boost and most likely turbo seal dead!)
thanks! sorry for the q's/
i am aiming for 220rwkw @ 4500rpm from a reliable turbo. engine h
Edited by s13rb26
https://www.sau.com.au/forums/topic/101048-2835r-hks-vs-gcg-hiflow/
for that power level the hiflow should do fine. you could just get your 2835 reconditioned with new seal and what ever needs fixing by gcg. i suspect the 2835 will make more top end power, but the gcg hiflow will have less lag. is the current amount of lag acceptable? if so then get it rebuilt. moving to powerfc with airflow meter will give you a better tune also
You mentioned the GT2835R was highmounted. Are you planning on high mounting an RB25 turbo intsead? Wouldnt that require a new intercooler piping setup, oil and water lines? Your setup is already tuned to accomidate the GT2835R. I say stick to it and just recon it. Seems to be the easiest way to go. And perhaps you should hope for the best, "TURBINE OIL LEAK" may simply mean a leak through the oil lines? (happened to a mate of mine recently on his GT28R).
Fingers crossed the turbo is still in good nik, your setup sounds awesome :rolleyes:
I would be getting the 2835 repaired given a choise , they can be rebuit if its only bearings and seals . If its chopped out the piston ring groove on the turbine there is a Garrett cartridge that uses the same turbine with a larger trim version of your compressor (assumes yours is 52T) . Buy , swap compressor and run .
When it gets here send me the turbo ID tag numbers and I'll see what is closest in the Garrett marketed range of cartridges .
Cheers A .
Edited by discopotato03
    • Whilst the brewery had good beer, I didn't rate the pork knuckle, the meat was good, but, there was no crackling, the skin was just thick and chewy Will return at some stage for the beer, but, I will wash the beer down with chips Plus, no sauerkraut, in what world do people serve pork knuckle without sauerkraut, they did serve apple slaw with it, which was nice, but.......#sauerkraut the world
    • Wow yeah ok. Given how specific you are about your car, I'm very surprised you are happy to do that.  As a bare minimum, without having a wideband gauge in the car or running it up on the dyno to check mixtures, there is no way I'd do that to my car.  You beat me to it, was going to say just this.
    • Yeah - that's not true. Larger turbos flow more at the same boost. By definition. I've always found it funny when the claim of same flow same power because same boost is made. The turbine is larger, therefore will put up a lower restriction to flow at any given flow, cf the stock one. Hence, you need less boost to make the same flow through the whole system. Hence, when you have the same boost as before, you must have more flow. -5s are a pretty decent bit bigger than stock.
    • That's basically how I've been driving my R33 for a while now. GTIII-SS running wastegate boost. It makes no more power than stock because the turbos aren't flowing any more air than stock. Eventually though I need to fix this so it can actually drive as it should.
    • If this was my own car, I would pull about 5 degrees off the CAS, run a wideband, and if that seems ok, send it.
