  • Replies 81
MC you can take you car, get driving tips and give it a good flogging. using their cars is a bit different and more expensive. more a corporate thing i think.
the event norbert runs is motorkhana and more competitive. better drivers and cars. you need the CAMS license and all the gear for it.
:alien:
:alien:
And how do you come to that conclusion ??
Ken
Originally posted by R34
Ken
I think he was comparing the Training day to Max Action event not MC to MA.
Have my first run at MC event tomorrow.
Hope I can sus out the 4WD handling
Cheers
Oh.... OK , yea you are probably right.
Enjo sprint is on at Wanners this arvo starting 4 till 10 pm
Am going up there.
Cheers
Ken
Ken
Cheers
morning or afternoon session? and what team you in?
Shaun
Alright - got an email back from John @ MC - took a while because he has been flat out since the MC Motorsport story on Getaway.
This is what he said:
5 people @ $185 each for a half day. You get heaps more track time, more expert instruction and I think it is a great way to get the most out of your car and yourself.
There are very limited days available over the next couple of months, especially the weekends.
I know it's expensive, but I'm still keen. Perhaps we need to look at the option of doing it on a weekday in order to get a spot.
Let me know if you are keen guys - remember it's only 5 people so first in, first served - I am flexible regarding timing so over to you guys.
Cheers,
Mike.
Shaun
Shaun
I was in the afternoon session 2 cars after you so you probably didn't see me.
I had the blue bugeye Rex in the WRX 2 team.
Never thought a REX could do power slides ....until now:)
Cheers
I held my own I guess.
Not sure as to the overall result but I came 2nd in the WRX team against seasoned Rex drivers so I'm happy.
Took a mega dollar 12sec WRX on race tyres to beat me though.
Once I get used to the car I'm hoping for an improvement.
Got approached by Norbert the organiser of Max action after one over the top sideways display and asked if I would enter the Max Action event next month....anyone have some Dulnlop R spec race tyres?:D
Shaun
Cheers
hehe the one with F**K ALL KM's on it? :)
twas some nice driving there, hehe
Shaun
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
    • More so GReddy oil relocation kits, sandwich plates, etc. all use 10AN fittings. And same, I've only used 10AN and my car sees track work (circuit, doing laps, not 10 sec squirt business).
