Well i was driving home this morning and came across something i would love to see every morning, 3 lines, 1 of which was MIZ33T, i think thats the plate.
I got to tell you girl, ur car looks better in real life than it does in pics
Sorry to MIZ and the other guy in the R33 for making you turn down toward Miranda, i guess u thought i was with yous. I was just heading home. I hope you hada good day to where ever you were going, i didnt understand what u said on the UHF.
Take care
Ronin
So is this an every sunday thing, just didnt see it on the forum thats all. i would like to come along if thats ok, pics look good, a couple of my car from behind hahah very good
lol! :(
7 skylines, a supra, an s2000 and a GSXR1000!!! :P
i wondered why my pbase hitcount was getting bigger and bigger ;)
yup. that was the dawn run...welcome anytime, for the past 8 weeks we've done it 7 times. pretty good effort, the week we missed was the Oz long weekend...
for me next w/e (16/2) will be the last for a while...so we should be organising Wakefield Park events when it gets cooler!!! :)
Hi there XXE-R32 hahahah yes..... i thought u were coming with us... sorrie if i was somewhat a bit playful driving next to ya ... i thought u were coming to NashO Runz haha jeeing u guys up!!
ps... nice little tail out action u did for the U-Turn in Miranda :(
more pics here! http://www.pbase.com/miz33t/dawnrunzviii
RONIN = franks going on holidays soonz... no more credit to dawn runz for him hahahahaha
Dawn Runzz are that best!!! nothing is compared to coming home sleeping 3am in the morning.,... waking up in 3 hours, going for a nice long twisty drive down the Nashos, CoLd refresging Dip in the rising sun, brunch at d gong, peerrves at a GSXR and cruising home for a nice shot nap!!!
next time i FIINK i will whiP out my CBR250 for a cruise ! any 988cc, 4-stroke, four-cylinder, liquid-cooled, DOHC, 16-valve, TSCC aint intimidate me! hahahaha :(
Well well great piucs, dont think im too keen on swimming that early in the morning, you would need balls the size of my wheels to do that.
So when is the next dawn run, this sunday i hear.
Where do you all meet up
    • I was using the wiring diagram I have So 12.74V is coming into the rear Fuel Pump relay as I measured.  When I turn the key to ON im getting 0.6V to the Fuel Pump plug; which i assume is backfeed voltage and doesnt include the 12V from ignition power.  The rear relay is working and being triggered.  From the diagram I clearly see the rear relay 80 = Rear Relay going into the Body/H loom (R-27) 27 = Fuel Pump plug going into the Body/H loom (T-20) 40 = Short Connector (R-27) I'm reading 12.74V on the blue/black wire which is the power for the Fuel Pump   From this diagram I can see the Ignition relay goes into the front and up to the ignition  2 = Fuel Pump Relay <1M> (R-27) 37 = ING Relay <1M> I started from the pump using this reference Which the way I read it (referencing Nissan wiring color codes) is: Pin Wire Color Function 1 B/P (Black/Pink) Ground 2 L/W (Blue/White)        ECU Trigger 3 SB (Sky Blue) Fuel Pump 5 L/B (Blue/Black) 12V Constant Tested SB to SB on Fuel Pump for continuity - confirmed Tested negative on Fuel Pump to 12V battery and L/B - confirmed 12V Pulled the relay putting 12V between Pin 1 & 2 and testing continuity on Pin 3 & 4 - confirmed relay   So that has me looking at this part of the circuit to understand whats happening here...and im still confused. From best I can tell; the disconnect is back to my previous diagram; between Ignition Relay and Fuel Pump Relay...which yet again; afaik is where the immobiliser should.    Thats what I was trying to explain to GTSboy; im not trying to fix it myself; yet I seem to have to get a Masters in Electrical Engineering (while im busy doing my actual job of DevOps & Cloud Engineering) somehow.  I just wanted more expert opinions; or more so that what I tested is correct and proves it to something around that area; to go back to the alarm tech (for a 3rd time) that he needs to fix it. He keeps telling me its not the alarm. He lives on the complete other side of the city so i understand not wanting to make a trip but as I said before if its the alarm it should be up to him to fix it. But he's adament its not; even though I pointed out the FP was immobilised through the original alarm. To my mind; it seems that the ECU is sending the signal; but the ignition is not getting 12V down the line.
    • Maybe also really stiffly sprung track cars. Get the inside wheel up in a corner and all the fun stops. Also me sometimes (rarely) when I have to stand on the brake to convince the diff to drive the wheel that is still on the ground when I'm trying to diagonally get over severe driveway entrance, etc.
    • I feel like I'm missing something. You had an authorised installer come out and install a new alarm. Post install the car doesn't start, and you aren't getting the installer back to fix what they did wrong?
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
