Hey Lads,
I got a RB20DET with twin thermo fans on radiator no air con condenser or anything all ripped out when driving my temp gauge reads....60-70 degrees which i think is a little low but once the car starts to sit in traffic it will jump right up to 90 degrees and start to over heating and start boiling the radiator fluid and spitting it out the over flow tank etc....
Im wonder i have a R33 Radiator in my car also would would be the best way of keep my car cool....vents in bonnet.
What about a new thermo stat that opened up earlier what would this help with.....can i please get some good import as with what to do about my position im in.
Im also putting in new knock sensors as mine are dead dont think this has anything to do with the heating issues but.
Thanks.
- Luke :(:):D
Another basic option is to hook one of the fans to a switch and just turn it on when the car is in traffic, i have it for hot nights and particularly warm days, if its gets any hotter than 1/2 then the other one kicks in due to the thermostat. But of late i did have a few issues with the radiator :(
If it's not overheating when driving around, but does when in traffic then your issue is most likley the thermos.
What size are you running and how are they configured?
Ideally you want to get the biggest fan(s) you can fit purely because they can blow/suck a lot more air than a smaller one (davies craig claim that a single 16 can flow more air than a pair of 12's).
Also, the fans can have the blades flipped over and the polarity of the wiring reversed depending on how its mounted. It would be a good idea to check that they have been set up correctly for your mounting style.
And last. Most fans seem to do a better job when blowing air through the radiator rather than sucking it through. If you can mount your fan infront it may help a bit too.
And flush your radiator while you are at it.
Good luck, overheating sucks arse.
I have 2 fans mounted on the frount of my radiator....i think i might need a new thermo stat as car runs on 70 when general driving but over heats in traffic etc.....
Might have a switch to turbo fans on and off for general driving then when slamming it turn them back on.
- Luke
If your really worried about it, take the thermo stat out of the car, and order a new one from nissan... my thermo stat is ruined so i just took mine out as im waiting for it to come from japan,with a few other parts. Car just takes a little longer to heat up thats all... not good for long term, but i figure its better then having the gauge on H the entire time (i.e cooking the engine)
Dayne
Mine does not cook but it will if i let it.....driving around daily its cold but not in traffic....i think i need a thermostat to make my car run hotter at like 70-80 degrees normal driving and for it to stay under 100 when i smash it.
- Luke
You're absolutely sure they work when the engine's running? And you're absolutely sure they BLOW air through the radiator?
I doubt the thermostat has anything to do with it overheating. If it was going to overheat, it's more likley to do it when the engine is working hard, not when it's just sitting idling.
The standard thermostat is supposed to be around 78C, IIRC.
Err..... have you changed the radiator yet or had it checked out yet? My mate had the same problem. We ended up changing the thermostat, water pump, timing belt, reflushed the cooling system and check the thermo-fans before we changed the radiator. I work at a delearship and the first thing you should do if you have overheating issues with those symptons should be to replace the radiator or have it fixed.
    • A few suggestions: Do you have the option of retarding your exhaust cam gear to bring the power band over to the left? VCT would be turned off after you make peak torque, you see the power/torque will decay faster with it left on all the way to the limiter Once VCT is turned off, you'll find the motor will take a bit more timing being ramped in Send its mum, more boost! Of course, depends on your exhaust pressure.
    • Tow a boat... people won't know wtf is going on 🤣
    • I was back on the dyno again yesterday after completely revamping my methanol injection system. I was making 440kw at 19psi. Great, this is more then I was making last summer with my old meth system at that pressure, and I figured it would be smooth sailing up to 30+psi. We continued increasing from there and by 25psi, I had only hit 455kw. Dyno sadly lost utility power at this point and I left. We seemed to be on course to hit the same power wall as last summer (477kw@27psi). This is a built RB25 S1 stroked to a 2.8. Built and ported head with Kelford 272/262 cams. Precision 6466 Turbo. Tuner last year believed the power wall is a mix of RPM limitations (Hydro lifters/Limit set at 7600RPM) and fueling. With my new meth system, we're seeing zero knock now but it still won't go up.  What else can I do at this point? Here's my train of thought.  - It's clear from the dyno graph that I would easily make power to 8500+RPM but I'm limited to 7600RPM. I could risk increasing my limiter, but hydro lifters have me worried. What are my options here besides going NEO head or solid lifter conversion? I'm rocking a 1.05AR turbine on my 6466. Would dropping down to a .84 help shift that power down in anyway? - We're only seeing roughly a 30kw difference at the top end with VCT on or off. Is this normal? I want to confirm VCT is working properly. - Should I look into other cam options?  - Should I just keep increasing boost and see if she wakes up later on? I would expect to hit 600rwkw around 35psi with my 6466.
    • First thought is to use a ram mount (to hold the ipad) + windscreen suction mount. The arms on the ram mount can be as long as you like, should be able to position the ipad pretty well with that setup.
