  • Replies 42
Gee they all this makes them sound like a real good turbo!!! lol
Laggy, weird design, china born.......im beginning to think they might be worth the little money you pay for them!!
THERE IS NO DUMP FOR THE Wastegate flap like Garret and EVERY OTHHER BLOODY TURBO.
http://www.turbobygarrett.com/turbobygarre...71_452203_1.htm
you mean like this one? It's also a fairly common arangement on hitachi, mitsubishi, and as a result trust internal gate turbos from the mid 80's to the mid 90's aswell. The v band arrangement isn't uncommon either.
You're talking about a turbo that is obviously old tech (at least the core) but it makes it's claimed power apparently and it costs bugger all. It doesn't mean i want to go out and buy one as i think you would be better off getting something a little easier to install (read common t3 exhaust arangement) and so save some money there that can then be spent on the turbo itself.
What i do like about these turbo's is they are obviously aimed at the performance enthusiast on a budget, the same as the china intercoolers and the china manifolds and the china radiators and the china coilovers, they offer 3 versions to suit your application, they have warranty, and they offer install if you can't do it yourself (which means warranty support).
well
similar exhaust outlet for the wastegate flaap.
end of story these turbos are for ricers who just want a "turbo car"
NOT A TUNED PERFORMANCE CAR! ( as the japs say)
POS TURBO!
so are you gonna keep bagging something without fact?
no one post has any.
That design wouldnt be so bad as its cleanly split, not like other int gate turbos that are close to the turbine outlet
nismoid.. i have facts
in my own brain from experience
ive tuned 5 cars with these turbos.. customers like them.. nice big top end power after 5000rpm till redline *usualy 8,000rpm* but they suck for street racing!
period!
drag only or watever
Edited by s13rb26
here is a lag diagram
on a ca18det
kkr 330(smaller one)
full boost between 3000-3500 not bad for a ca18 if you ask me.. good midrange as well
other mods it has is a z32 airflow meter and gtr injectors
Edited by fatz
Yeh i agree thats not too bad acutally. Seen as i would be looking at using it on an RB20 i would be looking at the smaller version, i.e. not the 480, i think its the 440?
And guys theres no need to argue, were all friends right?
......right :)
period!
are these the 480 on 2Ltr or 2.5Ltr motors?
If it gives me 250rwkw and full boost by 4000rpm I don't care where it was made...
my mat ehad one on his S14.. and yes IT IS LAGGY.... started boosting at 5000rpm..
Personally i liek RESPONSE@!!!
1.1 ex housing on an SR is going to be laggy, no matter what brand turbo. On an RB25 it may respond differently..
Getting back onto the original topic - does anyone have a dyno printout or experience with one of these turbos on an RB25?
thats the baby kkr330
totaly shit turbo once again........
will pop in no time
will pop in no time
been on for about a month
anyone who puts the 1.1 on small capacity engine is asking for lag
im frends with the distributor so i can get a 10% discount fo a limited time
i think he has sold over 40 units in 4 months and hasnt had one return under warrenty
pete
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
