i got a bit of knock reading after my powerfc tune, but its all settled down nicely
i got 195rwkw with similar setup (r32 gtr cooler with modified forward facing plenum)
i dont see knock above 20 these days
Spoooks - did you do anything to cause the knock to settle down?
I just got to knock of 61 as I got high in the rev range in 2nd gear.
you will see this kind of behaviour if u have the standard intercooler.
what happens is that after a few WOT (Wide Open Throttle) runs, the i/c absorbs a lot of the heat produced by the turbo, as to allow cooler air to be ingested into the engine. Although, this heat absorbed by the i/c greatly reduces the cooling efficiency and given that the standard i/c core is very small in size, dissipating this heat will take a while.
so what u need to do after you go for a nice WOT run thru all the gears, is cruise the car (off boost) for 5-10mins as to allow the i/c to release the heat by the flow of ambient air thru the i/c and monitor your intake temps and knock (if u can) at all times.
if you're not doing this, then your intake temps will be increasing quite a lot which would cause the knock that u see.
I had only given it a bit of a hit in 1st then 2nd..I dont think this is heat soak. The tuner reckoned I could take it to the track the way it is with the R34 SMIC on it..
I realise a FMIC would be a bit better though...
Edited by benl1981
Just to let you know I spoke to the tuner and a few others - apparently you can get a flash of the engine light in 2nd gear, knock sensors can pick up mechanical noise. Mine only flashes once or twice so may not be knock.
Mine hasn't done it much now.
Fuel economy is 10.65L/100km with some 15km one way trips (not too many traffic lights) and some longer 40km one way drives. Gave it a little stick from time to time but tried not to waste fuel by slowing and accelerating when trying to maintain speed.
I have probably gained 1-1.5L/100km. Difference would be more if you used a lot of throttle aswell.
At peak airflow - about 5010mV I think injectors were about 68% whereas before they were about 85% or something.
Don't be dissapointed with the power figure..
The 5010mV airflow figure reveals all.. :D
The dyno I run mine on I was pulling 4.98v to make 176rwkw.
So on my dyno with the motor ingesting 5010mV of air you would be pulling 180-190rwkw.
RB25DET's on my dyno generally pull around 190rwkw with 11-12psi.
So you are definitely making good solid power for 10psi.
Thanks Cubes. Yeah I'm pretty happy. You think the AFM voltage is a reasonble indication of power?
I'm getting the check engine flash a little in 2nd gear. I have seen knock hit 80. I called the tuner and he reckons that it is mechanical noise. When you lean out the mixtures he reckons that the silly mics pick this up more. He reckons he can richen it up and it will stop the knock readings but also kill power.
On the dyno he kept knock below 20. I also asked him if I see it flashing should I back off and he sort of said not really.
He is the tuner SK uses so is very good. Bit disheartening when you see the engine light flashing though..
just be careful though, I know every knock sensor is different, but my tuner said that knock in the head phones was audible when the Powerfc read 80 on the hand controller.
He said it was JUST audible, like barely audible at 80.
So If I keep mine below 40 I will be fine. 100 must be pretty bad though, I saw a few 100's pop up when I upgraded the turbo and had a ghetto tune in before I had a proper tune. Scary when you hear the popcorn sounds..
I think it is.... Its the amount of air the motor is ingesting.
How well the motor then uses that air is up to the tuner with regards to afr's and ign. timing. This is where its worth comparing WOT ign. values. :D
I've found on the RB25's that a knock reading around 40-50 can be heard through a chassis ear but is not audible to the ear, however a knock reading around 80 is most defintely audible to the chassis ear and the naked ear.
I find If I full throttle second gear on the flat I don't get much knock. But if I load it up going up a hill..hoild it at 3500rpm and hit it, I will get the 3 flashes from the check engine at about 5000rpm.
I might talk to the tuner again or get him to look at it. Don't want it to be unsafe.
Its well known cars with lower diff ratio's are able to get away with a little more ignition timing, increase the ratio (numerically decrease) and you will have to pull some ign. timing out.
It may be spiking a little at 3500rpm causing det also. :rolleyes:
The way mine is tuned now I can drop it in fifth up a hill and I will get high knock values... BUT how often do I do this.. never. :cheers:
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
