Anyone interested in cruising this friday? Jaffa has his car back so we're hanging to give you guys a run :)
Mind you, after last fridays accidents, taking it easy might be in order.
If anyone's interested shall we meet at the usual Mitre 10 spot at 9:00?
Post your thoughts!
GFXman
https://www.sau.com.au/forums/topic/10236-cruise-14th-february/
  • Replies 51
Hmm sounds like you softies aint keen.. (joke).....
well FYI there is a cruise that was posted on Performance Forums for saturday night.. details as follows:
Saturday 15th February
we will be meeting in the unmderground car park of mitcham shopping centre at around 9 pm. maps probably wont be supplied, well just go for a fang to some cool new drift spots weve discovered.
post back or pm me if your interested.
cheers
god invented shit
ford put wheels on it
Well I went cruising anyway - run into heaps of people out & about.Had my first drag in the EVO 7 on Anzac Hwy at about 12.00.I was in the middle lane, with a Gen III (Hyper 8) on the right, & an RX7 rotor on the left.Got the jump and held a good car length till 3rd when we all backed off.Go the EVO. Had Martin &
Susan in the car with me too!!
I saw quite a few Skylines cruising around but didn't recognise many of them.If I'm not busy tomorrow night I'll bring the R34 out
for a hotlap.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
