SOLD
Tomei Cams - 260 degrees x 9.15 lift:
Australia:
As New:
Change of mind:
$700.00 plus freight:
These are Spec B cams and were purchased from Japan and have seen little work. They are for the R34 GTT. Will suit the RB25 DET (NEO) engine. I am prepared to trade for a set of the Tomei Spec A cams with a cash adjustment (either way):
Contact murraybain@dodo .com.au or call my mobile 0400006864:
SOLD
Cheers
Muz
Edited by Muz
https://www.sau.com.au/forums/topic/102436-tomei-cams-rb25-det-neo/
Hey Muz.
Just curios why you want to change to Spec A?
What supporting mods would you have been putting with the cams?
Hey Bass,
I have all the usual mods and had bought these cams thinking I might go for a larger turbo but have since changed my mind and will go with a high flow (like you and Adam). After reading Adam's (Abo BOB) thread on here, I figure that the Spec A cams will be enough and still leave me with the very sweet idle I have at present.
Is this line of thought correct? Happy to be told otherwise.
Engine Mods: LARGE ARE intercooler. Z32 AFM, PFC, Nismo fuel pump, Nismo fuel reg, Nismo 480cc injectors, Nismo Twin Plate Clutch, Nismo 3.5 inch exhaust system, Nismo Timing Belt, Apexi Air intake, HKS Oil cooler. Some of this stuff is still waiting to go on (italics) and is just sitting in boxes on the garage work bench.
Almost forgot to mention the crowning engine bay improvement piece .... A genuine BASSJUNKY Radiator Air Flow Guide. :(
Happy to continue the discussion.
Cheers
Muz
Edited by Muz
That Radiator guide is good for at least 50rwkw. Why do you wven need cams?? :)
Well, my cam idles now at about 950rpm, sounds angry at the moment because of the turbo and dump pipe I had put on, so I'm getting it quietened down via a new read muffler this week. the Idle is smooth enougt I guess. It's sure as hell not a stock sounding idle, but it doesn't rattle or burble like a big V8 does with bumpsticks.
I'm super keen to see your power/torque/boost graph when you get it.
I think maybe you will make similar power, but maybe earlier and not hold it for as long as mine does (our to 7800rpm). Iff only it was as easy as swapping cams I'd do the exercise myself!!
On the freeway it's fairly inefficient. at 3100rpm, that's when she's most confortable crusing, but seeing as there aren't any 120 limited roads in Melbourne, it's a bit of a pain. Hopefully the Step A will be more efficient at lower revs.
BASS OUT
Thanks Bass,
Looks like I might have sold the cams to a guy in Germany as no realistic takers here in Oz. I'll post the graphs when I get it all done. Now to find a set of Spec A's.
Cheers and thanks
Muz
Edited by Muz
  • 3 weeks later...
