I have seen a 4door GTT tiptronic go for 19k (buy now price) fully complied on ebay...seller was down the Gold Coast. Prices vary a lot these days. Best is to do your own research. Imports are like a box of chocolates...u never know what you're gonna get :P
wrxhoon.... are you sure you didn't mean manual 34GT for $24k?  Most places I know are still selling GT-Ts for low-$30k...
No mate you heard right , a r34 GTT MANUAL ( as in 5 speed with a clutch ) 2 DOOR , silver with 6xxxx ks ( under 70 k ks) if you can believe oddos , in good nick , all stock with aftermarket headunit only , almost new tyres . Has been in the country for about 12 months and rego is due next month ( yes its registered in nsw ) .
If you have the cash and you want it just say so and i'll put u on to the seller .
I know of another one sold for $26 last week with 12 months rego , same as above but white .
It all depends.
All I know is that sedans are much cheaper
Silver ones are cheaper
Autos are cheaper
Probably the rarest and most exp would be a black manual couple, ~35k
Prices are still relatively high for a 5-7 year old car.
You may be able to find a good one for low 30k mark.
Some are at high 20's also.
they're usually $25,000 or more for a good R34 GTt coupe in manual if you import one (ie not from a local dealer). That's including compliance. Allow up to another $1500 for registration (depending on where you are).
although, one of the lads at work just listed these two...
http://www.j-spec.com.au/list/index.php?ID=4964
http://www.j-spec.com.au/list/index.php?ID=4957 (apparently its a rare black manual coupe :P according to the post above)
if you're willing to take a hit on what's considered high km for R34's (around the 95 - 105,000 km mark), you can get em pretty cheap.
Manual sedans were a little more expensive than the coupes at one stage thanks to the antics of a cetrain Blitz/Uras drifter. But now the market seems to have regained its senses.
I bet if someone bought one of these 2 by the time the get here they will have low ks just like the rest of them . Maybe i'm a bit cynical ? Its a fact all the ones i see for sale here have around the 30-40 k genuine ks .
lol I guess that's one of the perks of importing one straight from japan, you take out the step where there dealer winds back the k's to bump up the price.
