you'd want leaf springs..
but seriously.. kybs, konis.. or if you have some money - bilsteins.
Surprisingly, Bilsteins aren't all that expensive. When I bought new shocks, the Bilsteins were actually marginally cheaper than Konis.
do you have aftermarket springs on the car? Because i was wondering shouldn't you buy shocks that are suited to those springs. If you still have standard srpings then kyb's or go check out the group buy sydney_kid organised.
Now my previous paragraph brings me to ask a question. Some bloke my friend knows was changing his front shocks as they were worn out (car is r33 i think) to a set of shocks that suited the lowered springs he had on there.
I thought this was a bad idea as the the front and rear shocks are different. Is this a bad thing?
I thought it was as it would control the car differently so promptly told my friend he should tell his mate to change the rear shocks as well as they are most likely stuffed also.
I had standard springs with the Bilsteins for a couple of months. Felt fine, and the firmer shocks gave a large difference on their own... Sure, when I got around to putting them in, the Whiteline springs gave a bit firmer ride during cornering, but to be honest there wasn't as much difference as I would have thought.
As long as your stock springs are still in reasonable condition, its an option for a while.
so it is fine to run say bilsteins shocks at the front with say standard springs, and, at the rear have standard springs with standard shocks...
I just thought the the different shocks would control the car differently which would not be good. But i am most likely wrong as suspension knowledge isnt a strong attribute for me.
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 👌). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
    • Yes, unfortunately that's the one. Signal was noisy to begin with; after driving once and looking back at the logs I saw pressure constantly swinging between 0-200psi, or staying at 0 randomly for a few seconds. There's a lot of good sensors that share the same look and feel, so don't presume they're all bad. I bought mine for 20$ off Amazon and I should have read the reviews prior, as it's clear they're junk.  I purchased a lowdollerr motorsports sensor.
    • wedding eh.....I seem to get to more funerals than weddings or christenings these days....
