The Zeni Tani thing is all i know, i thought it was a Titanium turbine...i only know what i have found on the for sale adverts in overseas websites/publications and what the original owner posted on SDU years ago. Ill have a hunt around SDU tonight and see what i can see
thanks mate!
whats sdu??
  • Replies 193
Posted Images
Hey Bris,
Since you seem to know so much baout this car - how does it stack up against say Benno's or Sams?
BTW - Russ - you know about the Nov NSW excursion right? John (UAS) said he spoke to you about it and it would be awesome if you guys can make it down too.
I don tknow that much at all about the car. Liek i said only what i have seen in adverts here and there and years ago when the owner was talking about it on SDU. So dont really know how it compares to Sam or Ben's car.
Though i suspect it would be more Sams car then Bens, because of the weight of the thing...but really who knows?????
I KNOW its quicker then my car :wave:
oh and its faster than mine too! it doesnt go at all at the moment!! ;)
Neither does mine...first my car looked like this...
Then i hit something on the track...
Then a lap later the gods caught up with me when that damn cat told them who did it...
Which up close looked like this...
But JAG33 came dot my rescue...
So after fixing it i thrashed it around for while, was within a second of Snowman around Sandown the one session we did together...then parked it for a paint job which is about done.
I repeat, for the record...Sandown Sprint Session Three. The only time we have been in a Super Sprint together.
Lap 1
Bobo the Snowclown - 1:31.0100
Roy - 1:31.8900
Just warming up.
Lap 2
Bobo the Snowclown - 1:25.8500
Roy - 1:25.5800
Would have gone quicker but 1600kgs of steaming blue sh1t was blocking the track in front of me.
Lap 3
Bobo the Snowclown - 1:23.8200
Roy - Spun at Turn 4, but my Data Logger had me 0.4sec quicker then my best to that corner. I only spun because of the road block's corner speed was so slow that i almost t-boned it mid corner :D
How much power does your car have Bobo? How many times have you driven around Sandown Bobo? ... that was about my 10-11th lap in the dry.... :(
I would stop putting sh1t on my car as the fact that you are not really that much quicker then me in my POS, suggests something about someones ability to drive his finger up a dogs ass :mad:
Perhaps Bobos car is has never recovered from its stage fright either. I should mention my car isnt as pretty as yours either so dont have so many ppl willign to help push it
LOL... i miss all the smack talk on the Autosport site :laugh: Ive got nothing except personal attacks on a bloke who drivers circles around me :O
The top few inches of the guards and doors are painted gunmetal grey to match the stock colour of my car so you could either veeery carefully sand it back or paint the same section to match your car.
Just weighed them, bonnet is about 7kg (stock gtr ~10kg?), doors 17kg ea (stock ~30kg) and guards 1.2kg ea (stock gtr ~2.Xkg). That's with all electrics, hinges, handle, window, motors, speaker etc so i imagine you'd knock off a fair bit with an acrylic window.
Edited by neil_se
Just weighed them, bonnet is about 7kg (stock gtr ~10kg?), doors 17kg ea (stock ~30kg) and guards 1.2kg ea (stock gtr ~2.Xkg). That's with all electrics, hinges, handle, window, motors, etc so i imagine you'd knock off a fair bit with an acrylic window.
you have pm neil
Fire started when the heater hose into the firewall split and sprayed a mist of glycol ethanol over the glowing red exhaust housing/manifold...the stuff is flammable when in a 5% mist with atmosphere, and is preheated above 90 deg C. LOL a few things had to happen for it to ignite, if it happened a lap earlier or on the street it would have been just a coolant leak. It just happens the split was fine and the coolant temp was about 94 when it split.
I now run sheathing on the line to protect it from the heat
Ill ask what the PM is probaby about ;) How much do you want for the doors?
    • FWIW, I've aerated oil, and cams snapped. You can figure out the rest 🥲
    • Depending on the hose, sometimes engine out is the easiest option
    • Get an inspection camera up there.
    • Yeah, but look at the margin in viscosity between the 40 and the 60 at 125°C. It is not very large. It is the difference between 7 and 11 cP. Compare that to the viscosity at only 90°C. The viscosity axis is logarithmic. The numbers at 90 are ~15 and ~35. That is about half for the 40 wt oil and <half for the 60. You give up viscosity EXPONENTIALLY as temperature rises. Literally. That is why I declare thicker oil to be a bandaid, and a brittle one at that. Keep the oil temperature under about 110°C and you should be better off.   Having said all of that, which remains true as a general principle, if you have indeed lost enough oil from the sump that the pump was seeing slightly aerated oil, then all bets are off. That would of course cause oil pressure to collapse. And 35 psi is a collapse given what you were doing to the engine. Especially if the oil was that hot and viscosity had also collapsed. And I would put money on rod or main bearings being the source of the any noise that registered as knock. Hydraulic lifters should be able to cope with the hotter oil and lower pressure enough to prvent too much high frequency noise, although I am willing to admit it could be the source.
