  • Replies 1.5k
Posted Images
It will be interesting to see what happens when Ferrari get a motivated top line driver back in one of their cars. I remember how much the other Kimi upset Senna when he turned up at McLaren all those years ago. Senna had grown a bit complacent from having a second rate team mate (Andretti in this instance) & he really had to pull his finger out in the last few races before he disappeared of to Williams.
^^^^^^ yep thats what makes 2007 look exiting...I hope Kimi clicks with Ferrari and he has a huge season and maybe Massa can stick with him. Im sure this will put the wind up the sooky la la Spaniard.
I still cant see Alonso settling in as well in his new seat.
And what are Renault thinking with their 2007 driver line up????? No world champs trophies going to Renault for some time.
I just wonder what Kimi's reaction will be if and when Ferrari insist he starts doing dodgy shit a la Schumacher. Ron Dennis is painfully even handed with his drivers and painfully fair in his dealings so such things may come as a bit of a shock to Kimi.
I don't rate Massa. That he can beat Schumacher reflects badly on the German, not well on the Brazillian.
Why wouldn't Alonso settle in at McLaren? He has consistantly shown he can handle the massive pressure he has been put under (Alot better than some others). His comments on Schumacher were very exacting - great driver - not great for a number of other reasons. Hardly whinging.
Look how well Mansell got on with them. And Ferrari for that matter. And Williams. And Lotus.
Actually, back in the day Rosberg got on alright. As did Lauda. Even de Cesaris.
That it didn't work out for Montoya probably says more about Montoya than McLaren. After all he didn't really get on at Williams, either.
Let's be honest if Ron Dennis can get on with someone as difficult as Ayrton Senna, he can surely get on with Alonso.
Edited by djr81
My guess is that Mclaren and alonso will get on like a house on fire... They both take the same attitudde towards racing and both demand perfection from themselves and the team. I predict a great future for two of them.
Ron loves Alonso and im sure he'll try to provide him with best... because if he doesnt and Alonso leaves, Mclaren will have no top tier drivers to replace him
Actually, because he is such a talentless hack he only has to do it once to show that Schumacher is no longer at the top of his game.
ok...
so if schumacher wins the title this year, it'll show alonso to be a talentless hack, because he couldnt beat MS who is apparently losing his touch....
:ermm:
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
