  • Replies 1.5k
Posted Images
This from grandprix.com
The truth will out?
Nine years after the World Championship showdown at Jerez in 1997, the then Sauber driver Norberto Fontana has decided to tell the story of what happened to him during that highly-charged weekend. In an interview with the Argentine magazine Ol?, Fontana claims that three or four hours before the race Jean Todt visited the Sauber motorhome and told the Swiss team, which used Ferrari engines at the time, that the Saubers must block Jacques Villeneuve if they were in a position to do so in order to help Michael Schumacher win the World Championship.
Fontana said that he blocked Villeneuve for only three or four corners but that it cost the French-Canadian around three seconds. In the end Villeneuve challenged Schumacher for the lead and the two cars collided. Schumacher went off into a gravel trap and was unable to rejoin. Villeneuve won the World Championship and Michael Schumacher was later punished for deliberately driving Villeneuve off the track.
Fontana said that the action had hurt his career but that Todt and Schumacher never thanked him for what he had done. To view what happened you can go to: Video and make up your own mind.
While this is all ancient history now, there is a certain irony in that after the same race there were claims that Williams and McLaren colluded to rig the result of the race. That claim was rejected by the FIA World Council although it was never clear why the allegations ever got as far as the World Council.
The last teat at silverstone was quite interesting. Piquet jr topped the sheets first time out!! Hamilton... not so much. I really really hope that he doesnt get that remaining seat, theres people that have been around longer and deserve it more.
Silverstone - Great Britain 20 September 2006
1 N. Piquet jr. Renault 01:19.565 73
2 H. Kovalainen Renault 01:19.700 119
3 P. de la Rosa McLaren 01:19.921 110
4 F. Montagny Toyota 01:20.616 87
5 A. Wurz Williams 01:20.822 68
6 L. Hamilton McLaren 01:20.864 64
7 R. Schumacher Toyota 01:21.130 55
8 T. Sato Super Aguri 01:21.981 39
9 R. Quintarelli Spyker MF1 01:23.206 84
10 N. Karthikeyan Williams 01:24.031 39
11 S. Yamamoto Super Aguri 01:24.839 26
Hamilton has big raps on him, but how do you rate Nelson's young-un?
higher than Hamilton... Nelson seems better for some reson. I watched a couple GP2 races and i just get that good vibe from Nelson. More natural ability is all i can come up with, he seems to adapt to changes very quickly. And he seems to be fast no matter what you stick him in
oi.....lay off super-aguri bastard.
I never got my shirt >_<
i'll tell you a funny thing about Super Aguri merchandise. I was looking for some the other day, and came across a singed photo of Sato in a Super Aguri (may have been Ide actually). You know these things, a nice photo of the car pounding the curb, or taking the flag with the drivers signature over it. Well this one was a photo of a super aguri bouncing across the gravel trap!!! and personally signed by the driver. how golden is that. I should have bought it.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
