Does anyone know how many laps/hours Kimi has under his belt? It seems Luca Badoer is setting some reasonable times. Or do you think Kimi is waiting for the new car/year?
Edited by Savage Bliss
  • Replies 1.5k
Posted Images
McLaren won't let Kimi out of his contract, so he can't test for Ferrari until next year. Mind you, Ron Dennis is whinging that Renault won't release Fernando to test for McLaren before next year though.
And those new rules, :action-smiley-069:
oi! lay of super aguri all of you! you will be the ones laughing on the other side of your faces when takuma takes out the 08 drivers champ :miner:
That's about as close as he will get to winning, taking out another winner by rear-ending them!
those new rules looks shithouse. why does F1 these days want to completely re-invent the sport every farking year?
and Ivan, stop getting so excited by early testing. it doesn't mean shit yet.
The FIA are really trying to kill F1. Yhe whole idea of F1 is to be the pinicle of Motorsport, so the most money has to be spent. The cars should be diferent, non of this control parts bullshit, if I wanted that i'd watch CART.
Turbo's sound good though :P
im getting excited that Hamilton is acctually on the pace, and not just circulating... ill get really excited when all the new shiney cars come out in 07!! whos seen the pics of kimi in the ferrari garage? i still doesnt look right
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
