I'm sure you guys have had a chance to check out the JPNZ manuals (legitimate copies of course) of the Skylines. A couple of years ago I got the japanese service manual equivalents and was astounded by the amount of detail that was left out in the english translations. I guess it cost money to translate a lot of trivial stuff.
In any case, rather than stick around for someone to translate the stagea service manual, I bit the bullet and bought a copy of the Japanese service manuals on CD . I bought it so I could better work out a Stagea/Laurel/Cedric AWD RB25DET transplant into my R32 GTS4.
I bought my copy for $140, and its not that easy to come by due to some shrewd japanese auctioneers playing bidders off against each other. I'm happy to offer a copy of this to you guys for $20 (postage included to anywhere in Australia). I'll only be selling enough copies to make my costs back, after that you guys are more than welcome to do with them amongst yourselves as you please. Seeing as I just bought the manual about an hour ago, it'll be a week before I get the master copy, and a week after that before you guys recieve it. In this time I'll take expressions of interest in getting a copy (simply reply in this thread). Once the necessary number of copies have been accounted for, then I'll send em out.
Here's what's covered:
Models
  • 20G
  • 20X
  • 25G
  • 25X
  • 25RS
  • 25G-Four
  • 25X-Four
  • 25RS-Four
  • 25TX-Four
  • 25TRS-Four/RS-Four
  • 25TRS-Four V/RS-Four V
  • RS-Four S
  • RS-V
  • 20RS
Included Manuals (ID shown in brackets)
  • New Model Introduction - Sept 1996 (F046813)
  • New Model Introduction - Aug 1997 (supplementary Ⅰ) (F046844)
  • New Model Introduction - Aug 1998 (supplementary Ⅱ) (F046870)
  • Main Service Manual - Sept 1996 (A046001)
  • Main Service Manual - Aug 1997 (supplementary Ⅰ) (A046002)
  • Main Service Manual - Aug 1998 (supplementary Ⅱ) (A046003)
  • RB engine RB20E, RB25DE, RB25DET Engine Manuals Sept 1996 (A260W10)
  • R4W71C, RS5W71C and FS5W71C, FS5R30A Manual Transmission Manuals - March 1987 (A261B06)
  • RE4R01A Automatic Transmission Manual - March 1987 (A261C07)
  • F160 Differential Manual - March 1990 (A261D05)
  • R200, R200V Differential Manuals - March 1991 (A261D08)
  • ETX13A 4WD Transfer Case Manual - Sept 1992 (A261K02)
  • Steering Gear and Power-Steering Pump + Rack and Pinion system Manuals - April 1993 (A261H04)
  • AV System and Navigation TYPE I Manuals - June 1997 (A264A05)
  • Service Technical Information (STI)
  • Connector Summary - Feb 1993 (N200005)
Also includes the following diagnostic manuals:
  • CONSULT - Engine - May 1989 (J00E000)
  • CONSULT - Traction Control - Aug 1991 (J00W000)
  • CONSULT - AV system - Aug 1991 (J00V000)
  • CONSULT Common (revised edition Ⅰ) - March 1991 (J00M001)
  • CONSULT Service Manual - RB engine - March 1991 (J10E004)
  • CONSULT Service Manual - Automatic Transmission - March 1991 (J10T001)
Couple of screen grabs:
Now, ALL THIS INFO IS IN JAPANESE, so it may not be useful to those of you who don't have the patience to translate it or work it out. However it is still handy to have, if you have a basic understanding of how to read a service manual.
Again I repeat, this is a JAPANESE manual, not a translated english one. However it is more intricate and thorough than any english translated service manual I've read for a japanese import.
The manuals have been stored in Adobe Acrobat 7 format, so you'll need a compatible reader to open it. All chapters are bookmarked for easy navigation, and each book is stored as a seperate PDF.
https://www.sau.com.au/forums/topic/104317-japanese-stagea-service-manuals/
  • Replies 306
Posted Images
It covers series 1 and 2 from what I understand.
I assume these supplementary volumes are for updated engines etc:
Hmmmm, time for Japanese lessons? I know Japanese is not an easy language to learn, but like Terminal says, pictures can help make up for deficiencies in understanding what's been written for the time being.
When you get enough numbers, I would be more than happy to meet up with you when you're next in Sydney, if that helps. I'm only about 15mins from the Dundas area.
Cheers,
Nick T.
hey mate awesome find, and just wondering if it has wiring diagrams for the attessa system? and  general wiring for interior stuff etc?
if so ill grab one for sure :( let me know and ill send the cash once u r ready  :D
cheers
Brad
ATTESA wiring and diagnostics included, as are full wiring diagrams for the car. It also has a section on how to pull the interior apart if that's what you're after.
From looking at the fast software, it looks like the return line connects back into the surge chamber, i can't quite tell but it looks like the fuel pump mounts inside this, i'm guessing it's a plastic enclosure of some type.
It's showing the return line connecting into the bottom of the surge chamber (tank).
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
