I did a search and came back with 100+ results soooo...
I know there are three different types of plugs
Copper
Platinum
Iridium
I have heard of gaps from 0.8 to 1.1
Platinum and Iridium last longer but how much under normal driving?
I met a fellow member and he uses coppers every 10k.
Mine are Iridiums and they've lasted 100k.
I have learnt that the gap depends on the boost you are running, for stock the gap is 1.1mm if you are running 12psi or above 0.8 is recomended, as for plugs there is no perfomance gain to be gained from any but the life of the plug is greatly increased with platinum (80,000ks) and better still with iridium (100,000-160,000ks) compared to coppers which are recomended to change at 5,000ks although some say they last to 10,000 upto 40,000, if you can change them yourself go the coppers recomended below, I am using iridiums and they have been in there for 100,000k now and still good, I know because I keep pulling them out when something else stuffs up. Price wise they arent worth it really, I have been told that they are good in motors where changing the plugs are an absolute pain.
Generally speaking if a plug has a higher number than another it runs a colder heat range. eg. BCPR6ES ..... BCPR7ES colder plugs are good for preignition troubles.
Boost effects spark gap at 12 psi and above, the gap narrows down to 0.8.
FOR COPPER
They are good to 5k last at least 10k up to 40k
NGK for RB25det................. BKR6EYA or Platimum PFR5G-11
NGK for rb20/26det............. BCPR6ES or Platimum PFR6A-11
NGK for RB25NEOdet............ BCPR6ES or Platimum PFR6A-11
For PLATINUM
Good to 80k
NGK for RB25det................. PFR5G-11
NGK for rb20/26det............. PFR6A-11
NGK for RB25NEOdet............ PFR6A-11
NGKs Website
For IRIDIUM
Good to 150k
NKG for RB25det................ BKR5EIX-11
NKG for RB25neo............... BKR6EIX-11
NKG for RB20/26det........... BCPR6EIX-11
Denso for Rb25det............. IK20
Denso for Rb25det.. cold.... IK22
And go Here for a good SAU price on the Iridium plugs.
If you change your plugs and still have misfire isssues especially around the 3,000 - 5,000 rpm range it could be your coil packs are stuffed, its fairly common considering mine was 10 yrs old when mine started arcing out. Splitfire coilpacks are the best replacement and you can get a great deal from Dan (if he gives me a link)
  • Like 1
https://www.sau.com.au/forums/topic/104405-spark-plugs/
ok...I just did the biggest lot of finding this week...
Normal plugs for a Skyline RB25det -
You want the BKR6EYA's.
If you want to go a colder heat range, and stay in Copper, and NGK, get the BKR7E's.
As for Denso, IK20's for Iridium (Same as NGK "6" heat range) or the IK22's for Iridium Denso plugs (same as NGk's "7" heat range)
Denso copper - K20R-U - (same as NGK's "6" heat range)
Denso copper - K22PR-U (same as NGK's "7" heat range)
Use this tool, its the best I have ever seen.
http://www.denso.com.au/sparkplug/xref
Good luck finding any of the denso's you are after though.
here's a few tips also -
1. If the plug has a "-11" on the end, its gapped to 1.1 mm. If it has nothing on the end like this, its 0.8mm - 0.9mm gap.
2. Some have longer necks than others so be careful.
3. If you're running high boost and are running into pre-ignition problems, try "7" heat range (colder plugs) or 22 heat range in denso.
https://www.sau.com.au/forums/topic/104405-spark-plugs/#findComment-1923121
Updated iridium section
I'm hoping that when I get a complete listing that I can this stickyed in the app section.
Posted by WRXHOON in another thread
platinum and iridum plugs are better cause the tip is only .6 mm and u get much better spark . the reson the nickel plugs tip is thicker is cause if they made it that thin it would only last a few k's platinum and especialy iridium are much harder so last a lot longer .
typical life , nickel 30k k's , platinum 100 , iridium 150.
probably less in a turbo gtr driving it hard less still but still 5 times longer than nickel .
And this by MegaGTS4 Here
Bosch recommends when installing spark plugs to use a torque wrench and the correct torque in ft.-lbs. As listed below:
10mm With Gasket - 8-11 FT.-LBS
12mm With Gasket - 12-15 FT.-LBS
14mm With Gasket - 19-22 FT.-LBS
14mm Tapered Seat - 12-15 FT.-LBS
18mm With Gasket - 20-23 FT.-LBS
18mm Tapered Seat - 14-17 FT.-LBS
If a torque wrench is not available, hand tighten the plug until it is seated in the cylinder head. Spark plugs with gaskets should be tightened an additional 90°. Spark plugs with tapered seats should be tightened an additional 15°.
This PDF file shows how to read the faces of used standard electrode plugs: here
MEGA
https://www.sau.com.au/forums/topic/104405-spark-plugs/#findComment-1924930
what happens if you put the plugs in too tight?
I didn't really know how tight to put them in so I tightened them up pretty tight. Don't want them working loose?
Worst case scenario would be that you could strip the thread which would mean removing the head and then using a helicoil I guess :)
https://www.sau.com.au/forums/topic/104405-spark-plugs/#findComment-1925378
I am runnin iriway7's in my rb20
i just put new ones in the other did about 30k...but there was nothin wrong with em...just thought i would see how the change went.. Dont know the gap...but they seem to be real good.
https://www.sau.com.au/forums/topic/104405-spark-plugs/#findComment-1928025
If you are going to use a .8 plug then i would use a colder plug say a 7 in ngk, in the others i am not sure....but anything to hot and to close will cause detination.
That is a very bold statement to make. Do you have any evidence/theories etc to back that claim up?
Not having a go its just that a LOT of people run NGKs with a .8 gap and a heat range of six. It would be pretty fair to guess that its the most common plug configuration for an RB powered car that is running above standard boost. ( throw in coilpacks ageing and even standard boost cars run .8mm)
https://www.sau.com.au/forums/topic/104405-spark-plugs/#findComment-1928505
From what I've reseached so far the standard gap for copper is .8 and Iridium/Platinum is 1.1 some have shortened the gap to .8 in the I/P plugs due to high boost (12+psi) due to the spark being blown out by that much boost and the shorter gap fixed the problem, so it speaks for itself.
https://www.sau.com.au/forums/topic/104405-spark-plugs/#findComment-1930687
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
