From what I've reseached so far the standard gap for copper is .8 and Iridium/Platinum is 1.1 some have shortened the gap to .8 in the I/P plugs due to high boost (20+psi) due to the spark being blown out by that much boost and the shorter gap fixed the problem, so it speaks for itself.
For normal boost it's recommended to use 1.1mm gap, be it copper, platinum or iridium plugs. It's when you increase boost or HP you must reduce the gap (about 0.1016mm for every 50 hp you add).
NGK FAQ
Edited by Trex101
with old coil packs and running 18 psi, i had to go down to 0.6 with some "6" range coppers .. still blowing out up the top though... just under 300rwkw
new coils have arrived, hoping to run back to around 0.8 if possible..
Edited by Craved
This is not a simple discussion, the subject of spark plugs is quite complex. Following are some Skyline/Stagea specific clarifications based on my experiences;
Copper is a better conductor of electricity than iridium or platinum, so a copper plug can run a larger gap than an iridium or platinum plug. Iridium and platinum plugs are used for their life, they last longer, NOT for their performance. This is because of the increased service intervals and the high labour costs involved in changing plugs. The total cost over, say, 100,000 k’s is cheaper using iridium or platinum plugs than it is using copper plugs. That’s the case if you pay someone to change your plugs, if you change them yourself, then copper plugs are cheaper.
The numbers;
Copper plugs last for 8,000k’s and cost $18 for the 6
Iridium or platinum plugs last for 40,000 k’s and cost $120 for the 6
$18 X 5 is less than $120 X 1 = copper plugs are cheaper
But if the workshop charges you say $40 a time to change the 6 plugs = iridium/platinum plugs are cheaper.
Spark plugs come in a variety of gaps, for example NGK BCPR6ES come in 1.1 mm gap (BCPR6ES – 11) and in 0.8 mm gap (BCPR6ES – 8). Retail outlets carry the most popular part number (in this case BCPR6ES – 11). It may be that some popular N/A car uses the same plug configuration, so they carry that plug gap. It is NOT because that plug gap is somehow “standard” for that plug configuration.
As we increase boost (from standard) the inlet airflow and combustion pressure can literally blow out the spark. To overcome that we can either use higher output coils to give a “bigger” spark that will jump the gap even under the higher pressures. Or we can reduce the gap that the spark has to jump. Up to a point, reducing the gap has no real bad effects, but if we have to reduce the gap too far the engine will loose power. This is because there is simply not enough spark to properly ignite the fuel. An experienced dyno operator can pick this because he has to advance the ignition to hold the power. Advancing the ignition gives more time for the smaller spark to spread the flame. This is obviously a band aid, as we start to run into detonation problems if we advance the ignition too far.
My suggestion is (if you change your own) use copper plugs of the correct heat range and gap. If you can’t get the right gap spark plugs off the shelf, then gap them down.
Simple rule of thumb for DIY plug changers;
Standard boost = BCPR6ES – 11
12 psi = BCPR6ES – 8
Up to 19 psi = BCPR7ES – 8
Over 19 psi = BCPR7ES – 6
Until we get so much airflow that the standard coils won’t fire the 0.6 mm plug gap. Or the power drops off.
Then its time to upgrade the coil packs, go to CDI or whatever. We can usually increase the plug gap and start the process all over again.
Warning, this is not a definitive explanation, the result is a simple rule of thumb that you can employ. Then you can fine tune the slection for you own specific purposes and remember every engine is different.
:rolleyes: cheers ;)
:( cheers :P
It's true that copper are better conductor of electricity but copper is soft and doesn't less more than 10k. The new Denso/NGK Plat or iridium plug which feature fine wire technology (0.4-0.6mm center electrode) will provide much lower voltage then copper to jump the gap thus less misfire.
One disadvantage is the lower lifespan of 40k compare to 100k for normal plat or iridium plugs.
May sound dumb, but why do you change the heat range of the plug above 12psi?
My experience has been that you tend to get a bit of detonation reduction by lowering the heat range. This becomes more important as boost rises, I picked 12psi as the rule of thumb as that is when the standard turbo is usually upgraded. So it's a good time to go for a lower heat range plug.
1. It's true that copper are better conductor of electricity but copper is soft and doesn't less more than 10k.
2. The new Denso/NGK Plat or iridium plug which feature fine wire technology (0.4-0.6mm center electrode) will provide much lower voltage then copper to jump the gap thus less misfire.
3. One disadvantage is the lower lifespan of 40k compare to 100k for normal plat or iridium plugs.
Suggestion follow;
1. That's why I used 8,000 k's in my example.
2. True, but (there is always a but) the copper core still conducts better. All they are doing is trying to get back what they lost by going to iridium/platinum. They can't improve the conductivity, so they reduce the anode surface area to concentrate the spark. Some people argue that this reduces the size of the spark and therefore slows down the flame propagation.
3. Quite logical, since the anode is smaller, it wears out quicker. I have yet to find a car that doesn't get improved performance when the iridium/platinum plugs are changed at 40,000k's. This is despite the manufacturers claim of 100,000k's, they might "last" 100,000k's but the performance drops off noticeably over 40,000k's.
What I was aiming for with the original post was to give people an easy to understand and quick to implement rule of thumb. Not the definitive encyclopaedia of spark plugs.
:( cheers :(
Hey guys.
Ok just wanted to be sure on a couple things.
I gave the part number BCPR6ES to my Father N Law (who's a sales rep for an automotive company here in Canada) and "apparently" NGK has changed there numbers here and are now BCPR6E. They've dropped the "S" but when I punch in both numbers on www.ngk.com both types of plugs come up so I'm a little confused.
The ones I have are NGK V-Power RESISTOR TYPE plugs, #BCPR6E and I just want to know I'm all good to use these? I'm also running stock boost for now so according to what's been said I use a 1.1mm gap right?
Thanks for this fella's, I just want to know I have everything right so I can change my plugs tomorrow.
BTW, this thread REALLY must be a "Sticky" as it's full of great and usefull info that people can refer to whenever needed.
  • 1 month later...
I finally got around to taking them out.
Shape and form are unchanged and gaps were spot on @ 0.8. after 30k
The reddish colouring is not covered in the NGK FAQ anyone have a suggestion why these are reddish? Is it the I only run BP Ultimate?
The slightly darker NO.6 is an area for concern?
The reddish colouring is not covered in the NGK FAQ anyone have a suggestion why these are reddish? Is it the I only run BP Optimax?
The Reddish colour are usually due to additives in fuel. Did you use any fuel injector cleaner during the time your plugs in there?
For the foul no.6 plugs, it's normally due to carbon buildup on the no.6 valve or injector clog, since the rest of the plugs look ok.
IMO, the cheaper way you can do is to use a strong dose of injector cleaner like Redline SI-1(one bottle for the 1st tank, than lower dose on the 2nd tank). If that doesn't help then you got to sent the injector for ultrasound cleaning.
Thanks Trex101 will do an injector clean too.
Car is running great now, when I took it apart, for the plugs, alot of everything was loose, and with a light brass brushing I noticed a slight scale came off the plugs too.
Put the boost backup after some careful testing and holds fined through to redline cut.
I've used BKR7E or BCPR7EY (Copper V-Powers) and they have never have missed a beat. Lucky for me I have an SR20 so changing the sparkies are a 5 minute job.
Absolutely no fouling problems with a 7 heat range on a street vehicle.
If you tighten the plug tooo much they can be a real @#$%^& to get out.
The more feedback the better, just to confirm I am on the right track.
One trick i learn from old timer, coat a layer of grease to the plugs thread before installation. Set 30% lower torque to the plugs and you are good to go. It will never seize.
ive just finished replacing my plugs with bosch fr8 dcx with a 1.1 gap.
The car is detonating all over the shop. runs really smooth under boost. But if you put foot in, it just starts going put put put and hesiitating.
weird as it runs really smooth apart from that.
Help?! I am over this car!
    • Pressure when IDLING, is meant to be 51PSi... So that amperage value needs to go up a fair chunk... I'd personally be factoring for more like 12amp at least on those runs, and at that point you need to hope the already there wiring doesn't drop you a volt or two, as that's a lot of fuel pressure flow drop off from 13.5 to 12V! Taking idle pressure of 51psi, means the pump will be drawing a MINIMUM of 9amps all the time based on your reading of the graph (3bar base, then allowing an extra 0.5bar for boost = roughly 51psi)
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
