quick p.s to mederators.. WE NEED A INTERIOR SECTION!!!!!!
i have been searching for hours and cannot find any1 on the net that deals in automotive carpet in bright colours or does molded jobs for skylines not new 1's anyway i remember seeing a guy at the summernats that had piles and piles of mad colours if any1 knows his company name or anything it would be greatly appreciated as iwould any comany names or number in nsw that deal in this stuff, i am after some BRIGHT PURPLE carpet for my boot and floor any help would be greatly appreciated thank you,
p.s i live in NSW
Glen
https://www.sau.com.au/forums/topic/104708-auto-carpet-needed/
thought about that after i got of the net... only place in aus that does it good and good price is:
True Fit in mebourne Ph. 03 9792333
for anybody wanting to find kewl coloured carpet..
does anybody else here like the idea of a special interior mod section.. with thigns like fiting gauges and new seats to carpet and doing custom dashes.. just an idea of mine thought would be kewl..
Glen
hi...
when i got my interrior carpet i used boat carpet... you will probably find they have a slightly wider range in the boat carpet and the differences arent worth worrying about... its probably a little better quality because its designed to handle a soaking every now and then...
if you can, try and get the one without the backing glue... it goes into cornere better
i know this sounds a little far fetched but y dont u try bleaching your old carpet and dying it a wild colour of your choice... hell you can get a rainbow going if you a little that way :mellow:
Edited by Space Goat
  • 5 months later...
www.knoxautocarpets.com.au
its in melb, they might be able to freight?
I bought a black moulded carpet from them and it was very good.
I bought the super-ultra-mega-plush carpet, which was a bit of a mistake. In retrospect I should've gone for the lowest profile carpet, not the highest! :P
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
    • What sold me on Trailer Park Boys is this scene: Great stuff, just stay clear from the new Netflix production.
