is this car street registered ??
Yes this car is complied, mod plated and registered and i can organise a rwc for the buyer if interested.
Also i didn't mention this in the original post but i may be open to partial trade but only non turbo non import reliable (pref toyota/nissan) and 4cyl or less and only if its at a reasonable/realistic value.
Cheers
Jamie
PM's replied to.
Did a compression test yesterday afternoon, results were 150psi +/-5psi across all cylinders.
Cheers
Jamie
Very nice GTR-similar to mine spec wise Xept turbo's-who built it in Japan??
Garage Saurus???
Hi,
I believe Auto Garage Jin (not jun) did most of the work on the car and not sure but possibly may have been at top secret for a tune and possibly cam install as rocker covers are top secret gold and running fcon-v pro and top secret bag was in the car?
Cheers
Jamie
PMs replied to also.
Edited by «Cyph3r»
That is a phat GTR. The only thing left to do would be some Harrops and a front grill to complete it. Free bump. Good luck with the sale bud.
thanks mate.
all pm's have been replied to.
will have more pics up hopefully early this week ;)
how hard would this be to road register within victoria?
any ideas?
I'm very interested. will keep in touch
The car shouldn't be much trouble to get registered in other states, i got a rwc no problem and have been pulled over by the cops a few times now and driven away with no tickets. Different states may require a few minor changes but nothing expensive.
Due to being offered some silly trades i'll clarify im after a 4 or maybe 6 cyl car naturally aspirated non import and must be reasonably cheap to insure.
No more pics yet as have been in brisbane for part of this week.
Cheers
Jamie
Can vouch for this car, very nice and very quick, not for any limp dicks... good work jamie!
thanks brad :lol: it was on low boost when you went in it too, so much faster on 1.2!
That is absolutely bombed. How could you sell it! :yes:
I don't really have a choice hey, my priorities have changed and obtaining a decent career is now my main priority in life, so the car comes second :sad:
    • Pressure when IDLING, is meant to be 51PSi... So that amperage value needs to go up a fair chunk... I'd personally be factoring for more like 12amp at least on those runs, and at that point you need to hope the already there wiring doesn't drop you a volt or two, as that's a lot of fuel pressure flow drop off from 13.5 to 12V! Taking idle pressure of 51psi, means the pump will be drawing a MINIMUM of 9amps all the time based on your reading of the graph (3bar base, then allowing an extra 0.5bar for boost = roughly 51psi)
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
