Hey guys, just trimmed down my fan blades to clear my fmic i/c piping, i hear no end of ppl telling me they will run out of its efficiency as they are not all perfect, and one even said the water pump will die and that it wnt last any longer than 2 months!!!
What are your thoughts on all of this?, it was part of the HYBRID instructions so i couldnt see it being that big of an issue?, maybe an electric/thermo fan could help?
We've sold over 200 Skyline kits between the genuine Hybrid and Hybrid copy. I have NEVER heard of anyone having a noticable difference in water temps.
If you do experience any noticably bad differences maybe consider going with a thermo or 2.
Greg
installed a hybrid cooler and the intsructions were to trim the blades. trimming the blade causes it to become unbalance unless laser cut and is perfect on every blade. it cause extra stress and i have been told it is a really stupid thing to do by mechanics at various workshops.
just install some thermo fans like the davies craig ones.
ICER33-- hmm what rims are on that car in your display.. anychance u can send me that pic..
hmm anyways not from my own experience, but from sein it on friends cars, hes had no problems at all.. Has had the hybrid kit installed, with fan blades cut.. been over a year now.. no dramas at all.. n its a daily car, with all mods on.. so yea..
my blades have been trimmed also when my FMIC was installed.. no problems for me a year down the track
its not exatly a lot of rotating mass we are talking about here..
just because a mechanic says something, doesn't mean they are right.. most mechanics just regurgitate what they have heard before (from someone else), rather than have the ability to research an idea to determine if its actually plausible..
EXACTLY!!!
I have seen MANY cars with trimmed fan blades and have seen no noticable difference. It drives me nuts when I hear *mechanics* say that it will cause problems... errrrrr :)
After 4yrs, with a trimmed fan, my pump decided to start leaking, i honestly think it had more to do with the fact that the car is now almost 12yrs old.
According to my ecu, my engine temp stays at 84deg on a "usual" day and about 89deg on a hot day.
Look at it this way; your car is probably 12yrs old, if it goes (some time in the future) buy another genuine pump ($105 from Nissan dealer), then while the fan is off, decide whether you want to install thermo fans.
It is recommended to replace the pump after 100,000km, but not really crutial. When mine went, water only dribbled out, once the engine was turned off and enough pressure built up. Only noticed it the next day when i saw a small puddle (sauce pan size) under the car. My overflow and radiator were still full, so it didn't leak while running. Other experiences may be differant, but i dought it will "blow" causing major issues.
hehehe, i too hate "mechanics" speaking their garbage w/o actually having tested it out before in the real worl!!!, thanks again guys, i too have had no problems whatsoever, should i keep looking at the stock water temp gauge to make sure all is running fine?
Mine was trimmed back about 20mm (by me), run successfully for the last 12500km. Same result - does not overheat, vibrate etc.
The one word of advice is to make sure you radius your corners similar to stock. If you leave them cut off sharp then apparently they make a lot of noise.
FWIW, my mate runs a rally car, and finds that the engine driven fan WITH shroud is far more efficient - at controlling temps - than thermos. The downside of course is parasitic drag when it is not required; even with a clutch hub.
cheers
Dale
IS installing a Thermal fan that bad??? Also wouldnt you save a little HP by installing a Thermal fan?
No; and Yes.
The original question was whether there was a problem with trimming blades on a stock fan.
Properly installed thermos will work well, but at a cost.
cheers
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
