hi guys, Stace here..........I have posted 7 packages 2day at lunchtime. I have sent them to:
blk180
N1GTR
Beer Baron
600ZILLA
West
Black R32
9krpm
Hope you all get them soon. :P
  • Replies 419
Posted Images
Anyone in the first group buy has hooked it up and how did they go?
Any experience with wiring, where to mount best....ect?
Instructions with pics are included in the package :P
Edited by DiRTgarage
hey paul... sorry mate, I thought this was an adaptor loom for the ECU, so count me out of this one. My fusebox has already been tapped with a switch.
Got mine today. Very neat and pro looking for a simple device. Strongly recomend any R32gtr owners out there who can't afford big bucks aftermarket items.
Thanks Paul n Stacey. Let the fun begin, to run serious 60ft time in GTR's, you'll need big burn out.
Gotta say i could have done this myself since we sell all those wire, fuse...ect here at work but for $35 and supporting a potential 9sec GTR team, why not :w00t: ?
Keep up the good work Paul n Stacey.
Thanks for the feedback guys...we like to buy quality ourselves and its great to offer a product that is simple to use and value for $$.
(removes salesman hat)
recieved mine yesterday. cnt test it yet coz car is in pieces, but should be able try this weekend. Looks brilliant! Very professional. MAXIMUM RESPECT! (and now with the instructions i know all the fuses under the dash, seing it's all in jap. thanx)
Guys...feel free to post pics of you testing this device......on a private road of course.
Disclaimer:
DiRTgarage in no way condones breaching state traffic laws.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
