  • Replies 419
Posted Images
parcel sent to AWDMAT.
3 left peeps be quick
Paul, I've received the switch thanks.
QUESTION - The instructions show a picture of your console with mounted switch. Is the 'Line Locker' a seperate device? Or is this simply a light connected to the 2WD switch you make?
Pete
Pete
The line locker is a separate device altogether....its for locking the front brakes during a burnout or to stop the car creeping on the line. The switch for it is on the gearstick.
Is this the line locker/roll control?
http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...mMakeTrack=true
Do you have a photo of the switch on your gearstick?
Picked up my switch from PO BOX today, will let you know how i go with installation and results.
Cheers.
*Just fitted the switch this afternoon. Took me about 15-20min all up.
I mounted the switch in the removeable panel that covers the fuses under the dash.
The instructions are very clear, and it all went like clockwork. Looks very neat aswell.
Ill give it the final test in the next few days, a quiet piece of road somewhere... :unsure:
Just a quick question. With the switch set to "ON" is the car in normal 4WD mode, or 2WD mode?
Edited by mazgtr
Cheers.
Ill give it the final test in the next few days, a quiet piece of road somewhere... :D
Should be 4WD when "on" but as its a single pole single throw switch, polarity is not critical....so check it out before mounting.
BTW due to the popularity of switches another batch of 10 is being made.
payment made 1 and a half weeks ago
still have not recieved anything??
whats going on??
Your parcel was delayed as per our PM to you...its been a big week at DiRTgarage i hope you can appreciate we had a lot on last week...but your parcel was sent friday. Please PM if you don't recieve it so we can sort it out for you.
Thank you
Paul and Stacey
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
