Can someone confirn that the dash in this picture is an R33 Series 1? I'm sure it's not a Series 2, but don't really know what a Series 1 looks like.
Also, does anyone know if there is a difference in the general dash layouts between R33 two and four door models?
All will be explained later in a thread about dash trim kits on Ebay.....
Thanks!
https://www.sau.com.au/forums/topic/105467-r33-dash-series-1/
Looks like a S1 non turbo as there is no boost gauge. The only difference between the surrounds on S1 and S2 is the coating. S1 have a rubber film over the top where as S2 are a hard rough plastic finish. 2 door and 4 door dash's are the same!
the steering wheel in that pic is covering the area where the boost gauge would be, so you can't really say if its a GTS or GTS-T.
definitely a series 1 though
Thanks guys.
Turns out it is a 1995 GTS-T, so in other words a Series 1.
The problem I have is that the dash trim kit I just got from the US which is supposed to fit 94 - 97 models doesn't fit my S2, because it was designed to fit on the car in the picture.
Bugger!!
  • 3 weeks later...
Dunno if it's just me, but i've noticed that series1 has that little coin-tray thing next to the mirror-fold buttons.... mine doesn't have that.
Oh! And my dash surround is a rough horrible black/grey.... I hate it. I can't clean it with anything without it shredding whatever i'm cleaning it with.
It looks like a series 1 dash surround to me too, distance shot so hard to be certain. as Jackie said if it is flat across the hazard and demister switch then it's a series 1, and it also has that smooth rubber coating as boj01 said, and the coin slot too. Series 1 Antenna height switch is inset in dash and series 2 is flush with dash.
I had one on my series 2 when I got it so yes they are interchangable, even the gearshifter surround is, which also has the different surface finish. The tray in front of the centre console box and ashtray's may be different in textures across models also?
Definately a series 1 airbag steering wheel, and no passenger airbag.
Edited by Fry_33
ahh ueah, the antenna switch, my series 2 has it but by looking at series 1 they have that cion slot, so guessing series 1 dask would look weird in a series 2 bcause of the size difference?, might be safter getting it sprayed my self
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
    • Yes they do. For some maybe. But for those used the most by abusers, ie Skylines, the numbers are known. The stock eyebrow height for R32/3 Skylines is about 365/375mm or thereabouts. The minimum such heights are recorded in adjacent columns in the database.
    • Hmmm, interesting. Makes me wonder whether there is bias as well. It's the cheapest fuel, so it is used for all kinds of ill-maintained shitboxes which are bound to have issues regardless. Nicer cars tend to require higher octane rated fuel and can't use it anyway. FWIW, the official NSW E10 facts page is decent.
