hey just a quick question im unsure about, saw a r33 the other day with a huge ass flutter, liek really loud. anyway pulled up to him at the lights and asked him what bov he was runnin or whatever, and he reckons hes blocked of the standard bov ( r33 gtst). Sounded alright but just wondering if blocking of the standard bov would be harmful to the engine (they were obviously put there for a reason). He also mentioned it was runnin 10psi. Would that put more strain on the turbo, as theres no bov in action. Im sure your thinkin ohh no not another bov thread, but jsut from experience what would the likely conclusion be with a setup like that. He said the car was stock apart from boost, 3" turboback and fmic.
THanks heaps guys much appreciated.
https://www.sau.com.au/forums/topic/105848-blocked-of-standard-bov/
haha, talk about opening a can of worms...
From what I hear, from reputable sources, ie. mechanics and tuners, no it wont harm your turbo, your engine will idle shite and stall though. Above 14 PSI it is recommended that you use a BOV, but even then alot of drag car buliders still dont use them.
1) open turbobygarrett.com
2) browse to technical area
3) read up on the blow off and recirculation valve systems
4) understand how it affects the turbocharger system and what happens if you block it
it will harm the turbocharger end of story
We tried this trick whilst doing the turbo upgrade... I can confirm that it idles like shit and stalls... don't do it if you can resist the sound factor.
If you want flutter etc, get a proper BOV.
its all urban myths and drift / vl turbo hype
it makes the response worse
it causes compressor surge
it puts stress on the compressor wheel and shaft
there is nothing good about running with no bov
no bov on either the r32 or the s13 (sr20) and no probs on either gonn put the boost up on the s13 to bout 14 pound and see what happens but the 32 is boositing bout 11 pound happily and with a little lag that its always had. the 32 has a supra front mount on it the s13 the stock side mount. both have pods and stock turbos. i wanna put stainless intake pipes on to make it more enjoyable. i personally can see the point of a bov in a hi boost instance but in both my cases whic are pretty low i feel it shouldnt make any difference. the 'stress' they say it puts on the shafts of the turbo should be minimal as it would be more engine braking then anything else as the exhaust gases get caught in the engine more as they would slow down also in proportion. i feel its a matter of taste to go with or without BOV. until someone shows me a turbine that has shatter due to this i will keep our cars without running BOV unless i can get the chinky one like the M3 out of the mischief dvds lol
Edited by daler32
Noone will show you a turbo that is rooted due to running no BOV. Its "theoretically" possible, but NOONE has proven it and NOONE will. Its myth and BS. I have two s13s that have never run BOVs and turbos are still in excellent condition and both have been running for 16 years....
BOVs are to reduce noise.
BOVs are to stop your cooler pipes from blowing apart if your piping is dodgey.
Thats it.
So please, before another person says no BOVs damage your turbo, post some proof. Guess it stops there, 16 years of no BOV for me is proof enough BOVs are not needed.
Now its just a personal preference what sound you want, flutter vs everyone-look-at-me-I-sneeze.....so keep it at this cause it wont be proven BOVs damage turbos.
noone said blow off valves in general damge the turbo....
only that blow off valves blocked to achieve the ghey flutter noise is harmful. read and understand fully before posting.
second of all if blow off valves arent needed why do they come stock standard with them in the first place?....
please read http://www.skylinesaustralia.com/forums/in...ic=60655&st=100
it was recently discussed
i believe the bov was fitted to prevent turbine and compressor damage. i dont believe it has anything to do with noise, emissions, looks. purely servicing on the turbocharger components and to prevent excessive failure/wear and tear
K what about this for proof then say what u will, correct me if im wrong ok.
RB20DET R32 yeah its got a bov, Goes "shhhhhh"(or whatever) due to bov
VS
RB20DET Laurel, Cefiro no bov, Flutter due to no bov.
OK im not sure if the turbos are different but theroedically(spelling) u could block the bov off on the r32 to make it the same as the Cefiro or Laurel.
Yeah whatta think? Is that proof? or not? dunno.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
    • My experience with Rising Sun Exports Before agreeing to the sale I tried to do as much research as I could (obviously), his Facebook reviews are 98% and he goes Live at least once or twice a week. I contacted 2 people in the UK who had used him for their imports, both had positive feedback. His explanation and talk through of the import process was thorough, answering any query no matter how stupid it was. It felt as soon as the money was sent, communication dropped off. I asked for shipping updates every 2 weeks or so, not wanting to pester him, he never had any updates. I wasn't informed the car had been dropped off at the port, I only found out by his Facebook story. I asked for the photos taken at the port, knowing he would need some for insurance purposes. I received a few 5 second clips and that's it. When asked again, he said his staff had them. Weeks later I asked again, he tells me he doesn't have any, but does have 50 photos from the original advert. I never received them. I eventually got the documents sent via WhatsApp after I mentioned the port was requesting them. I purchased a CarVX report, to find out the vehicle is a Grade R with recorded accident damage, first recorded in 2017 when it was first auctioned. He never told me the grade, then again I didn't ask. His response was "Grade R means nothing, it wasn't chassis damage". Still, I would have liked to have been informed about it. Jon prides himself on being open and honest when it comes to inspecting cars, it's his main job doing so at the auctions for customers. When the vehicle arrived in the UK I noticed a few little cosmetic issues. It's a 21 year old car so it wasn't going to be mint condition. The side skirts are cracked on each corner and the sealant is failing. The front grill on the bonnet/hood isn't secured very well, mounting studs are missing. Both minor things, but again, it would have been nice to be told. During a Facebook Live walk around video of the vehicle, he mentioned it has a front Whiteline anti roll bar/sway bar. While on the inspection ramp, I noticed the stock item has been installed. When first questioned, his response was "the ARB? Switched? Since when, it never had them". Since sending video and photo evidence I've not received a response. I'm probably being over critical of the overall condition of an old car, but all I wanted was honesty (which he claims to have). I'm aware I wasn't his only customer, he's busy doing XYZ but other reviews praise him for great communication with regular updates and photos, I felt I didn't receive the same treatment.
