Ok lads help me please
i have an auto r33 gtst and want a resonable brake upgrade as it will be the next line of moding
has any 1 done 1 and wat did you do or wat are you thinking of doing
thanks in advace
i did a search
james
https://www.sau.com.au/forums/topic/106584-r33-brake-upgrade-options/
I have slotted 4000 series DBA rotors, Hawke pads, braided brake lines, brake master cylinder stopper and Motul dot 5.1 fluid on my 33 GTST.
I have so far yet to run into any fade during the 5 Lap Sprint sessions at Queensland Raceway. Had the Same combination on my old 33 GTR also with the same results.
4 x 4000 series DBA rotors approx $800
Pads Front and rear $400ish
Braided lines were $80 per corner
Cusco stopper $120ish
I did this a while ago so not sure on exact prices, but that will be close.
There is no labour included there as I did it all myself.
I have to give the Hawke pads a big thumbs up though, they are a bit dusty, and squeal if not used hard for a while but by far they best pad I have used so far. The made the biggest difference.
I would do the pads 1st, change fluid as these made the biggest difference, then probably the braided lines, the others were more cosmetic I think, couldn't really pick a difference with them.
I need an upgrade to!
On my old vl i just had bendix ult pads and braided lines, the car stopped on a dime. Then i put on cross X/slotted rotors which just improved it more.
When can't you use DOT 5 fluid? When you have standard lines? is this correct?
GTR_Legend the max you would want to run with standard lines would be DOT 4. DOT 5 is more acidic which eats the standard rubber lines but on the other hand the fluid remains cooler longer and gives you better pedal responce.
Miller the hoon whats your budget? Brand new Porsche 6 piston brakes with 350mm or 365mm rotors for $4000. your are looking at spending a minimum of $1500 on better pads, rotors and braided lines. other oprion is try and get some R33 or R34 GTR brakes.
I know a few people have stated that with a decent pad and maybe some DBA slotted rotors you should be laughing, depends on how much you want to spend, technically that should set you back about a grand.
I think newtown has it right with just the pads and braided lines first and see if that gets you stopping faster. Could also try endless pads off nengun.com good price, and great pads.
thats what i thought, just wanted to make sure
Thanks for the info lads
sick r31 i think the budget will be 1500 to 2000
there are ather things i am looking at but stopping would be the smartest 1
Fronts aswell at this stage
for gtr ancors should i go to wreakers for this or go new
do braded lines do much as well?
james
If you are going to upgrade the rotors, in the group buy section they are selling caliper mounts so you can use bigger rotors IE GTR rotors. I'd be seriously thinking about that since you are replacing them anyway!!
Then the usual good pads and fluid.
braided lines help, as your stock rubber lines get old the brake fluid is acidic and starts eating the rubber away and they become soft, perishable or may start to bludge in areas. get someone to put there foot on the brakes and you hold one of the lines, it should expand a little, by the line expanding you are having to put more pressure on the brake pedal to get the same brake responce if the lines were new. you shouldn't pay more than $60-$70 for braided lines.
if you are planing on going bigger rotors and calipers in the future just get a brake master cylinder stopper for now. if you are going to go GTR brakes only worry about the front as the back rotors are only 3mm bigger and 4mm thicker and when people see brembo on a caliper the price doubles pretty much.
For $1500 you could buy some GTR Brembos, plus another $1200 for 324mm DBA 5000 rotors and say $400 for EBCs.
That's similar to the set up I had on my GTR. Then spend $2800 on CSC front kit with 343mm two piece rotors with stainless lines. Very cost effective upgrade.
TBS automotive Queensland, they buy all their stuff through this company so just find the closest distributer to you, i attached the link below. this wasn't mates rates either. also roy how much were you quoted to get braided lines?
http://www.braidedhoses.com.au/wherebuy.html
I already have braided lines. And those lines are technically not legal on a road car...they may be safe, but as they havent beebn tested to a recognised standard i wouldnt be putting them on my car
you mean the lines i have?
Not sure exactly what kine syou have...but lokign closely at the website...they seem to be legal...BUT, some of the wordign sounds like my local member come election time :P
brake hose manufacturing ‘specialists’ Australia wide that have pledged to manufacture your Stainless Steel Braided Brake Hoses to comply with the requirements of the Australian Design Rule (ADR).
It states Australian Design Rules ADR7/00, ADR42/04 & Department of Transport and Regional Services
(DoTaRS) approval CRN30886 as specifation.
So it all seems ok, but i dont see why they state all of the above, and dont simply state that they have been tested and legal? My understanding is you can pledge to do it, design something to the ADRs, but if a component hasnt been bench tested then technically its not strictly legal???
Im not an expert, but looked into ages ago when i had mine done, and the devil was in the detail where there is a bench test which flexes the hose so many times for so many hours to makes sure the conneciton where the rubber sleeve is doenst fail....liek i said im probably beign paranoid or misunderstand the legislation.
..and its kinda off topic so sorry :P
    • My thought is if you were just moving it forward and the upstream geometry remained the same, then no difference at all. But because the current one has the filter direct into the AFM inlet, you effectively have the best chance of a completely symmetric air flow profile upstream, and in, the AFM, whilst the aftermarket inlet thingo has a (small, to be sure) bend between the filter and the AFM. That would bias the flow to the outside of the bend (downstream of the bend) which might well reduce the size of the signal seen by the AFM, for the same total flow rate. Having said that: If you're proposing to make your inlet look like a hybrid of your existing one and the aftermarket one, such that there is no bend where the filter is clamped on... then I say it will be just fine. If there is going to be such a bend, then, if you can align the insertion of the AFM blade such that it is at right angles to the plane of the bend, then there is a better than even chance that the centreline velocity where the blade is will remain more or less the same, and the velocity will just be a little faster to the outside of that, and just a little slower to the inside. **This is not professional investment advice and you should consult a suitably qualified ouija board, tea leaves or the intestines of a goat for more accurate prognostication.
    • Hi Tao, Thanks for your reply.  It's been a while and I managed to get the valve stem seals replaced with the head on the car.  Unfortunately this didn't solve my issue, the car still smokes a lot after idling (to be honest during idle you can see a bit of blue smoke from the exhaust), same after deceleration. I will try disconnecting the valve cover breathers, do I leave the PCV valve in? By engine oil drain pipe, do you mean the turbo oil drain?
    • What about if you just give it direct 12v and earth?
    • Hi guys . Can someone help me  I bought an Android screen for my Nissan fuga but it won't turn on
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
