  • Replies 181
Posted Images
Well I was one of the dobbers, but I've pm'd about the delivery too.
the other thing I was interested in was whether anyone had fitted them yet, and how you went about fitting? or if you had them fitted somewhere how did they do it? and how much? I'm keen to try and get these in before the end of the month as I have 2 trackdays coming up.
I just came home and the package was in my room. So no problems here.
Although if anyone can post up instructions that would be awesome. I was thinking of fitting pineapple rings at the same time.
I received mine today. They are impressively big and heavy. Should make a good conversation piece when I set them up on the coffee table :P
Bl4cK32: Thanks for all your efforts, particularly given Noltec's... err.. slow response. It must have been difficult to be caught between an unhelpful supplier and people demanding their product.
Bl4cK32 posted up some instructions somewhere that explain the process, although if Noltec has some it would be nice to get our hands on those.
As for where, I am fairly sure someone (Duncan?) said Nathan recently pressed in/out some sub frame bushes for them. Your other option for removal is using a hacksaw to cut to the metal surround and hammering out the bush (as an optional extra, you can burn out the rubber :D)
The use of pineapples will only be usefull for angling the cradle to aid traction and create a little more squat.
Obviously for this to work correctly the rear camber needs to be spot on.
yeah I was thinking maybe heat the subframe till it's nice and toasty with the oxy torch, then try and bash them out. but if nathan has pressed some out before successfully then that will be the way I go.
it seems that I'm only a day behind with delivery. I just seemed to remember they were posted last thursday and I kind of thought they would be here monday. so being wednesday got a bit nervous.
edit: $250 fitted doesn't sound that bad to me. if it's drive in, drive out.
This thread has been reopened as some members involved dont seem to have received the parts they paid for.
How can i be held responsible for Australia posts slow service...its obvious people live all over Aus, and i had deliveries to WA to Qld, so expect some delays.
I havent ripped anyone off, in fact it ended up costing me in postage, so be thankful that i still chose to do this out of my own pocket before closing the gb.
It is the last time im doing it, as im sick of the hassle, and 50 pms a fortnight. AS well as everyone second guessing me that im gunna run off with everyones money.
I have a trader rating, and have been part of these forums for a long time, with more people to act as a character reference i thought some would have faith in me.....obviously not.
i think we are all cool. :D
I dont think Blitz was having a go. Just stating that delivery was yet to occurr in some cases, and giving some advice to sort it asap. You could probably read that sentence 5 different ways, with different toan/inflection etc. but I dont think he was trying to break your balls. just explaining why the re-open.
I appreciate your efforts! :P
so the real question is, who will win the race to be the first guy with some fitted? and the first on track?
thats fine. Just thought people might have some faith in me, and patience with the postal system.
I could have offered express post, but who wanted to pay $20 for postage, when u can wait 3 days.....?
haha, i have no patience. I just remembered that the were posted on thursday, and usually from anywhere to sydney is only 2 or 3 days (so was expecting them monday or tuesday). guess they just got lumped on the slow boat!
fark knows....yours may have fallen behind a shelf at the post office and is long forgotten :laugh:
My attempt at a quick installation guide : http://www.skylinesaustralia.com/forums/in...amp;hl=subframe
Edited by Bl4cK32
guess what just arrived in the morning mail? :P
Farking aus post. 1 week from SA to sydney. that really sucks.
thanks mate :)
I may even get these in next week. Will have to see how I get on.
guess what just arrived in the morning mail? :blush:
"...Farking aus post. 1 week from SA to sydney. that really sucks."
Damn their oily hides! I'm in Perth and i'm still waiting. I'm, hoping theres a letter from my post office today asking me to pick up yet another suspect looking package :blush:
Thanks Bl4cK32 for organising this GB, dont stress. It's cool.
    • I know why it happened and I’m embarrassed to say but I was testing the polarity of one of the led bulb to see which side was positive with a 12v battery and that’s when it decided to fry hoping I didn’t damage anything else
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
