Hello
I am new to this forum site.I would like to know what is the highest HP at the Rear Wheels produced by an Rb25 motor.
I currently have a GTST skyline and with the standard Rb25 motor and pumping out 498 Hp on 18 PSI.It is a manual skyline.I am running a Standard Motor,GT3540 turbo,Custom plenium,750cc Injectors,Hydra Computer,125 mm thick cooler with HKS style end tanks,3 " intercooler pipes, 3 "exhaust,Aftermarket coil packs.The engine has been run on the dyno about 150 times checking things and testing as i am trying to prove what the standard rb25 motor is capable of.
I am wanting to see who has made more hp.A dyno sheet is available and the dyno is on my own Dyno Dynamics Dyno running shootout mode.Intake Temps on the dyno sheet are 34 degrees and the room temp is 30 degrees.
Thanks
PS this is on Opitimax fuel.
Edited by LNEMUP498HP
https://www.sau.com.au/forums/topic/106775-max-hp-out-of-standard-rb25/
Yeah buddy
im going to be using this car for drifting and drag.
Its my business vehicle.I own Wild 1 Motorsport along with my Father.The vehicle is going to get rego next week as while i was building it i ran out and yeah i will be driving it.
Yeah completely standard. I Have got another motor i am building with h beam rods, Forged pistons,ARP main,conrod,Head stud kit,Cometic head gasket,Tommie cams and springs which i will be dropping into the car as soon as something goes wrong with this one.I thought i will prove ppl wrong about the standard motor.
498hp on std rb25...mate that is impressive. Now we just gotta wait for someone to come along and say 'thats a load of the "proverbial"'
What sort of knock you getting on your current tune?
  • Like 1
i am going to put the new knock sensor on tomorrow.The old one would detect to many vibrations for the engine on idle.
When i used the stithoscope or however you spell it.The knocks were very minimal.I am going to using c16 in it and see the power difference.
As for the Dyno graph I will do it with Hp And Boost to shut ever one who doubts it up.
If no 1 believes its standard. They can pay me to pull the motor out and if it is they can pay me if it isnt i will pay them.
No 1 should Doubt the POWER OF a NISSAN RB motors.
Nice work on the power figure :D
GT35's tend to make power well.
I dont think standard means much at this stage...
Make it last 12 months with SOLID work... and make sure you post backup if its still running as thats the real test, one that no-one has passed.
No winding down the boost either :O
You so adamant about "shutting people up" what are you trying to prove?
Anyone can run big power in a stock motor. A few power on the dyno runs doesnt impress anyone but the 15yr old kids :D
I saw 500rwkw+ from an internally stock RB26.
Needless to say it lasted not very long at all and died a dismal death
LOL
turn the boost down
the boost isnt going anywhere.
as for the motor
if it blows ahh well
i got my back up motor waiting.I wanna push the engine to its limit
runing just under 18 psi wont hurt the engine the head gasket is the only thing i see wreaking and the engine is reving to 7500
i will keep every one posted on how the engine goes and lasts.
You still have a little way to go, I have seen 550 rwhp out of a ZeniTani built R25DET (standard internals) using a hi mount T78. But like all RB25's with more than 320 rwkw, it didn't last very long.
It's not about "how much" power, but for "how long" it makes that power.
I have a question;
Hydra Computer
What ECU is that?
;) cheers :)
Edited by Sydneykid
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
