  • Replies 75
Haha, another Team Trackday hijack.
Actually, we are deciding between 350z convertible and TVR Tuscan. We were 99% on the TVR but no-one has got SEVS approval yet.
Not interested in the porker.
Originally posted by EnricoPalazzo
SilverArrows: I doubt it wasnt run in. When my mate first got his S2000 my excel could keep up with it. So im guessing the engine on the Z wasnt run in at all.
:confused: If this ment for ed?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
