www.otomoto.com.au have a big selection of new KKR turbos at relatively inexpensive prices... check them out... I guess it depends on your want and need for the turbo upgrade to produce and on your supporting mods...
Cheers
Edited by QUIKBLADE
https://www.sau.com.au/forums/topic/107094-turbo-upgrade/#findComment-1978469
Gee they look ok. I guess you have to get new oil and water lines and the dump pipe section. Not bad prices there though.
Hopefully this will bring the prices of other turbos down - such as GCG turbos.. I would buy one of those if they were only a grand.
Edited by benl1981
https://www.sau.com.au/forums/topic/107094-turbo-upgrade/#findComment-1981407
Looks like good value - but are they ball bearing??
They do look good quality tho.... for $899 plus $149 for a dump & some cut/rewelding of my current dump pipe, not too shabby at all.
Edited by bwilkeson
https://www.sau.com.au/forums/topic/107094-turbo-upgrade/#findComment-1982642
There is an R32 that HPI are building that uses a KKR 480 turbo. They said that it was a plain bearing type, and needs some minor modifications to get it to fit but the dump pipe that they have on their site makes things slightly easier. They were quite happy with it though, anyone else have experience with these turbos?
https://www.sau.com.au/forums/topic/107094-turbo-upgrade/#findComment-1982970
Mate keep in mind that if you're upgrading your turbo then you'll need the following at an absolute minimum.
Fuel Pressure Regulator - $200ish
Fuel Pump - $250'ish
Aftermarket Fuel Management - $700ish
Tune - $300ish
Intercooler - $1000
Lines/adapters for turbo - $300ish
Installation for all - $500ish
Now that's just so the thing runs. Anyone doing a proper turbo upgrade would get the following.
Fuel Pump
Aftermarket Computer
Intercooler
Full Exhaust
Injectors
Induction
Boost Control
Clutch
Tune
which will take the cost close to $10,000.
You sure you know what you're getting yourself into?
https://www.sau.com.au/forums/topic/107094-turbo-upgrade/#findComment-1984564
Will some people already have the powerfc. I'm currently getting around 175rwkw and my injectors are only at 70%.
So I reckon I could get about 210rwkw without even needing a fuel pump upgrade.
To get to about 240rwkw I reckon I may be able to get away with a new pump and FPR.
Clutch is a nissan patrol one that feels pretty strong at the moment.
I think 220-230rwkw is down the track eventually what I'd like to safely have. Maybe wouldn't need a new AFM for this.
Even 170-180rwkw makes a pretty fast street car..
Tune - $300ish
Intercooler - $1000
Fuel Pump
Intercooler
Full Exhaust
Injectors
Induction
Boost Control
Clutch
Tune
https://www.sau.com.au/forums/topic/107094-turbo-upgrade/#findComment-1984599
Got all of that gear ready for the turbo (less injectors, wont get them until I buy a turbo)
Fuel Pump
Intercooler
Aftermarket Timing Computer
Full Exhaust
Injectors
Induction
Boost Control
Automatic Oil Cooler
Tune
Ive done the right thing and got the supporting mods ready and installed, tuned to 160awkw at 12psi on my 4wd auto Stagea. But time for a turbo.
Good value - would they last a few years these KKR thingies? Id need to modify my current dump pipe, but for $1100 plus new oil lines (dont use water lines with KKR) and install, plus then new injectors and retune of SAFC/SITC and boost to 15psi, still as cheap as getting a hiflow turbo.
Researching further.............
https://www.sau.com.au/forums/topic/107094-turbo-upgrade/#findComment-1984615
light switch means laggy doesn't it
:confused:
What happens when you turn on a light switch? The light comes on straight away.
So I'm sure you can see what "on like a light switch" means.
Also, is it just me or are there three different users all posting the same replies in this thread?
https://www.sau.com.au/forums/topic/107094-turbo-upgrade/#findComment-1987532
Cheers
I submitted a post today about KKR turbos got some interesting answers check posts for -KKr and Monsta turbos, anyone used these any good? alot of mods needed to fit these sort of cancels out the money you save
sorry dont know how to include the link
Im also thinking of an upgrade but not sure what to get i was thinking maybe 2835r Im still pretty new to this so dont know whats needed, engines stock, stock cooler, heavy duty clutch, split front dump and 3" exhaust on the way, saving for powerfc cars of the road at the mo was thinking of doing the full RB25/30 thing but from what Ive heard lately thats beyond my projected budget so im most likley either going to rebuild or drop in another stock engine so all I really want is a bolt on solution thatll give me a bit of extra pwr without any more problems, so if I leave the engine stock what turbo would be best?
Edited by BOVed
https://www.sau.com.au/forums/topic/107094-turbo-upgrade/#findComment-1987542
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
