hi guys.
can any one tell me if 2002 model wrx sti gold brembo calipers will bolt stright on my gtst[r33] or not??
i know that the distence btween the mounting holes on the r33 calipers are 100mm. but dont know whats on the sti gold brembo calipers. :D
so can any one help me pleaseeeeeeeeeeeee :(
thanks guys...
Edited by neo31
you will have to modify the rotors on the front and back to fit them, the center hole is 10mm smaller than the GTS-t ones. after you have done that the fronts should bolt on without any other troubles, but with the back you will have to use same washers to space out the caliper from the rotor as the height of the rotor is about 4mm bigger. here is all the specs on the 3 different types of rotors, personally go get brembo GTR calipers less work involved fitting them.
R33 GTS-t
Front A) 296 B)53.75 C) 30 D)68
Rear A) 297 B)63 C) 18 D)68
R33 GTR Brembo's
Front A) 324 B)53.75 C) 30 D) 68
Rear A) 300 B)63 C) 22 D) 68
WRX Sti Brembo's
Front A) 326 B)53 C) 30 D) 58
Rear A) 316 B)67.5 C) 20 D) 58
gotta attack the lower control arm with a hammer to bend it in so when you go full lock the rotor doesn't rub on the arm. the red circle is part you hammer in.
other than that machine the center hole out 10mm and you might have to use 1 or 2 washers to space the caliper to fit, but i don't think you will have to as GTR rotors just bolt up with no other modifications and Sti rotors are same thickness only 2mm bigger .
Here's the specs on the HR31 rotors.
HR31 GTS
A) 274 B)47 C) 22 D) 68
thanks sik r31 mate for the info..
so you bleave that sti calipers will bolt stright on hr31with no mods on the mounting holes..am not realy worrie about the rotors beacuse i'll get new one anyway. but what dose worrie me if they are 100mm space like r33gtst or gtrs..
am icluding 2 pics for sti and gtr calipers . it look like to me the sti calipers mounting hole difrent to the gtr ones... the front calipers pics are for gtr. and the other full set are for sti...
cheers mate.. B)
Edited by neo31
they look the same to me just metalic paint on the GTR ones, its the angle that the pics were taken on that gives you the impression that they are different. pick common points off the calipers and compare the two pics side by side. also i thought all jap cars Nissan, Mazda, Misubishi, Subaru and Toyota all had caliper spacing of 100mm just like aussie cars such as ford and holden have 90mm spaced calipers.
let me just pull a set of GTR calipers and Sti calipers out of my arse and measure them for you. oh wait they want about $1000 for each pair of these calipers. maybe you wouldn't mind sending me $2000 and i will go get the verniers out of the shed and tell you. maybe instead of being a wanker keyboard warrior post something useful.
just rang my mate that has a 2000 model WRX and he is using 2003 brembo Sti gear on his car and the caliper spacing is 100mm so the only thing you have to do is ring DBA and get some custom rotors made to suit your HR31 neo31 . also omrae read my first post i said "personally go get brembo GTR calipers less work involved fitting them" that is a direct bolt on upgrade no engineering required i know this cause i helped my cousin do this to his R33 GTS. And what degree of engineering is required to upgrade brakes? goes to front desk at university "i would like to enroll in automotive brake upgrade engineering". so what background knowledge or experience do you have omrae.
hey sick r31.
you'll be suprise if tell you that i went this morning to one of the sti wrecken yard and they had 2004 sti statuary rid off .. and i mesere the mounting holes with my Verniers and find out they where 150mm inserf [[100mm like gtr ones]] .... i was surprise mate ...so maybe you mate was wrong about telling you that sti calipers are 100mm.. so i think i have to find out who can make another mounting bracket to fit them on my car. :(unless you know someon who makes them...
cheers mate.. ;)
Edited by neo31
why do you so badly want Sti calipers? just get some R33 GTR calipers.
[/quote
beacuse they are a lot bigger than the r33 gtrs and even bigger than r34 mate. :starwars:
if you see the caliper size of the sti ones you'll be sprize man a bout them....
thanks.. :)
yep the STI brembo is better than the factory R33 and R34 GTR caliper (i think you'll find that the R33 and R34 are the same except for the colour).
They're both leading calipers so at least that's ok.
As far as I can tell, you'll want to:
1. measure the mounting point to centre of caliper distance of the two different brembos (i.e the distance from mount holes to rotor centre to see if you need to offset the caliper
2. consider the stock rotor sizes (the skyline is 330mm or something around that)... what is the STI rotor diameter? I'm pretty sure that hte STI rotor is smaller than the GTR rotor...
3. I reckon because the STI rotor is approx the same or smaller than the GTR rotor, it will be a pain to adapt a bracket... if the rotor was bigger you could space the caliper out further from the hub with a dog bone bracket and get some 2 piece rotors to fit
4 Unless... the STI caliper can swallow a bigger disc without too much pad knock off then you might be able to do a dog bone bracket to mount the STI caliper....
sorry for the random thoughts, hope that made some sense and added something to your deliberation :|
If the subaru caliper mounts to the front and the gtr caliper mounts to the rear of the upright how can they both be leading calipers, unless they aren't differential bore calipers
yes, upon further review the STI are trailing.
Sorry neo, wrong info there mate.
Will be more pain than it's worth unless the diameter of the pistons on the STI are the same (i.e. they are not differential bore - fancy name for different diameter pistons) and you can use swap the LHS and RHS calipers... otherwise if you try and mount a trailing caliper as a leading and vice versa you can't bleed it easily
PS you're wrong too omrae - the GTR mounts to the front (leading) and the STI to the rear (trailing)!
:tongue:
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
