  • 1 month later...
just jump onto the tacho wire at the back of the dash cluster. use a test light to find out which 1 it is. it will be a thicker wire. just start the car and try all the wires with a test light. the tacho wire will flash (very fast) and if u rev it it will get brighter ( cause it is flashing faster)
i might add a note when checking for tacho pulse it is important to use a led test light as these do not draw any current in which could harm igniter or ecu if you use a lighht bulb test light it could over load the circuitry causing failure
just my two cents
using a normal test light or an led test light won't make much difference. but it depends on that u are testing. testing the tacho wire between the ecu and the tacho will have less affect than testing between the engine and the ecu if something went wrong. and using a normal light would draw similar current to a monster tacho.
i used a normal test light on my last car when i was hooking a shift light up (still used factory tacho though. no point putting in a 5 inch tacho when there is already 1 there) and there was no problem.
fair enough to use 1 if your car doesn't have a tacho or the factory 1 is dead.
  • 1 month later...
just to help anyone out who is reading through, the tacho wire on the r33 ecu is a yellow with a blue stripe wire. when the ecu is still bolted in, it is in the top row (right hand side when the ecu is vertical) and 4th pin up from the centre bolt. its not the 4th wire, as some cars have different wiring configurations due to different options, but the 4th hole in the plug.
  • 5 months later...
  • 3 weeks later...
i have connected my rpm signal to the ecu output which does lead to the back of the cluster, but i dont know if anyone has had the same problem where the tacho doesnt read right as the output from the ecu is a 5v square wave and the autometer tacho needs 12v square wave. is there a way to fix this without buying extra modules to convert the signals.
  • 1 month later...
Yeah I have the same problem.. no idea how to solve it though.. hope someone has an answer..
  • 2 years later...
that advice is spot on.
thanks mate, helped me to put my digital tacho in by myself.
don't seem to have the same 5v versus 12v problems as everyone else though.
it's the $99 dollar one from justjap, inbuilt shift light too :)
  • 1 year later...
This was one of the only threads I could find that helped with installing my eboost2 so I could use the rpm function. I didnt have the instructions which are on there website, but what I came across was when connected up, the main tacho stopped working. after putting a 2k ohm resistor inline to the eboost they both now work correct.
    • If they can dyno them, get them dyno'd, make sure they're not leaking, and if they look okay on the dyno and are performing relatively well, put them in the car.   If they're leaking oil etc, and you feel so inclined, open them up yourself and see what you can do to fix it. The main thing you're trying to do is replace the parts that perish, like seals. You're not attempting to change the valving. You might even be able to find somewhere that has the Tein parts/rebuild kit if you dig hard.
    • Can you also make sure the invoices on the box (And none exist in the boxes) are below our import duty limits... I jest, there's nothing I need to actually purchase and order in. (Unless you can find me a rear diff carrier, brand new, for stupidly cheap, that is for a Toyota Landcruiser, HZJ105R GXL, 2000 year model...)
    • Murphy strikes again! Nothing at all would have gone wrong if you had the tool kit in the car! You'd have just found the clamp loose the next time you went to touch it...
    • I have been being VERY quiet about what you're alluding to, as it is something that ticks me off... The number of cars from factory that run coil overs is HUGE! Most of them these days do... The other part that annoys me, is people saying "Well all the incabin adjustable suspension is illegal by blah blah blah"... If that's the case, then why can I buy a car brand new that can do it if, FULL STOP in cabin adjustable suspension is illegal...   Also, I could just chuck some aftermarket shocks in my car, throw the stock springs on, after my blue slip, dump my super low springs back in. Same shock and spring style setup... Hell, they could also be the same colour springs etc.     I'm voting, BlueSlipper didn't want to touch the above car for some reason. Whether it be some sort of bias against the car, the owner, them maybe having previously done dodgy shit and now they're being super careful in case they get slapped in the face by the Gumbyment again... Find a new blueslip place.   And can confirm as you had said, yes there are holy bibles of vehicle heights, and all sorts of other suspension stuff. Heck your run of the mill mechanic, and tyre shop has access to all of that stuff. It's how they do wheel alignments...
    • Funny story Heading to Sydney this morning on the HWY there was some slow traffic, so I gave it the beans and midway through my overtaking "power run" I lost all power It seems that I missed a hose clamp,  and the MAF and filter went WiFi To make this more problematic, the little tool kit that lives in the boot, is sitting in the sun room at Goulburn......LOL Luckily for me I found a bit of steel on the side of the road that could be used like a rusty and bent flat head screw driver to tighten it up enough that it got me into Sydney, it is now all tight like a tiger with the aid of a 8mm socket Note to self: Use my brain and double check stuff, and always keep that little tool kit in the car for when I have a brain fart
