where are you located? when i had flucating idle with my powerfc after 2 years of trouble free operation i had to perform a reset to fix itself up. i just copied my tune before i reset it and then reloaded the maps back on once done. it sorted out my wierd idle stuff no problems. do you know any local who has datalogit ?
if you have a standard computer and want toreset it, disconnect the battery.
step on the brake pedal while th ebattery is disconnected.
this will drain power completely from the car.
once you connect the battery back up, start it up and take your car for a thrash.
the ECU is fresh and learns from the first drive and sets timing and idle as required.
well that's how it works for R32 ecu's anyway.
reseting is the same on both cars.
but as for learning, not sure about R33's.
    • Hi guys my TPS voltage is reading over 2v at idle.  My Haltech ECU is reading around 40% throttle position at idle also which is really strange. Note the actual throttle position sensor is brand new…    anyone have any experience with this or know how to calibrate it on Haltech ?
    • The OEM disk will not work on any AEM ECU, you need to use the one they made. You shouldn't have to flip the CAS or whatever you were describing, if you set the ignition sync offset correctly it can't backfire. Make sure you're using a spark plug lead on coil 1 instead of the timing loop to avoid weird issues with the timing light. Double check that your timing settings are actually correct, like is the 24 tooth configured correct or should it actually be 12 teeth for 1 crank revolution? I also found this: 305817248-AEM-Undocumented-Settings-v1-2.pdf
    • Yeah, I don't believe the M35 uses a deadhead system.
    • Have you done your thinking backwards? 3 bar, 43.5 psi pressure drop being the presumed specification for an injector, means you need 3 bar upstream when they are firing into atmospheric pressure, and more upstream pressure than that when on boost (you add your boost to your rail pressure to maintain 3 bar across the injector) and you need..... less pressure upstream when you have vacuum in the manifold. So, presuming that you're idling at -10 psi, then you only need ~23 psi in the rail. I realise that I did not need to say all of that to you specifically Matt, once you'd realised your mistake. It's mostly there for complete clarity for others.
    • Have you reached out to the guys at Spool Imports? They are a Ross dealer, I can imagine they would have the rings just sitting on the shelf (I could be wrong).
