kinda off topic, but what I'd really like to see (well more so HEAR) is an RB31 hi compression in NA form using the 6 throttles with trumpets on them, with a hi flowing exhaust.
sure might not make the power of the turbo ones, but it would sound awesome.
even more off topic, anyone got that video clip of the original race GTR which they pulled out for a few laps of some jap circuit that was being renovated or something..
awesom sound...
As for talk about RB30s beign truck engines, its kinda funny. You look at M3s, some of the greatest 6 cylinder engiens gettign aroubnd, you read the reviews of its revvy nature etc...yet ppl seem to think dynamically the RB30 cant rev ????
yes but spend m3 engine $ on an rb30 and the rpm outcome might be impressive. not the same of course because bmw are vv smart, but impressive nonetheless.
Sorry, I wasn’t being very clear with my post. Basically the RB30 has an 86 x 86 bore and stroke. And people say that the long stroke etc amongst other things means it wont rev hard. But you look at the latest M# which is generally considered to be a banshee and revs happily and it has an 87mm bore and 91mm stroke. So it actually has a longer stroke then the RB30 which invariably means higher piston speeds etc etc.
So dynamically there is no reason why an RB30 cant rev hard. Ok, fair enough cams may hurt power up top unless something has been done in this area, but if the rods a re good quality and balanced well,, ditto the pistons, especially with a turbo on the side of the thing it should happily pull good revs.
This talk of balancing etc.. I hear that some guys here are using old 270 000km bottom ends..doesn't sound like they care too much about balancing.
For a street car looking at 240-260rwkw - would you just buy a RB30 bottom end - if the pistons look ok just put new rings on and new big end bearings? Rehone it..
Would you really need to balance? Only plan to rev it to 6500rpm
Just going to be putting a lot of kays up on the car for new job so thinking of building a spare bottom end for if and when it needs a freshen up..
Also what turbo - GCG standard highflow...Would this not choke it up high..?
Sorry to deviate a bit.
yeah i think the hiflow is too small for the rb30det
i think the gt30 is the smallest you can run that wont run out of puff
and even that is still a bit too small, i think the gt30r or gt35r is spot on
would you just use the RB25 to make that kind of power rather than go to all the hassles of building the rb30 and swapping the engine, blue slip with new engine etc?
easy make 260-270 rwkw with std rb25..
personal choice for sure. then again, you might be in an r32 for all i know lol so then i would do it :whoops:
An RB30 with 260rwkw makes alot more torque than a RB25 with 260rwkw, some people swap to the RB30 because of the better drivability, and lots of extra torque.
fair call!
anyone noticed any increase i fuel consumption with the lower powered (220rwkw etc) RB30's V's RB20 or RB25's?
Well I'm also considering the cheaper option...It's only if my motor bombs out..
If I have a 3L bottom end with a freshen up there it is cheaper than an imported RB25 engine.
Anyone have any comments on my questions above? Maybe I should make a new post or something..
fair call!
Im getting around 10L/100Km atm out of an untuned pfc.
I cant run it up on boost, due to the coil packs wont take it (break down and piung like a bitch)
Its makes hella fuel economy as everyday driving is under 3500 rpm.
hmm thats what i used to get out of the std RB25.. will have to see. looks like there isn't much difference between the rb30 vs rb25 etc..
get a nice tune and that should improve i'd be thinking!
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
    • If they can dyno them, get them dyno'd, make sure they're not leaking, and if they look okay on the dyno and are performing relatively well, put them in the car.   If they're leaking oil etc, and you feel so inclined, open them up yourself and see what you can do to fix it. The main thing you're trying to do is replace the parts that perish, like seals. You're not attempting to change the valving. You might even be able to find somewhere that has the Tein parts/rebuild kit if you dig hard.
    • Can you also make sure the invoices on the box (And none exist in the boxes) are below our import duty limits... I jest, there's nothing I need to actually purchase and order in. (Unless you can find me a rear diff carrier, brand new, for stupidly cheap, that is for a Toyota Landcruiser, HZJ105R GXL, 2000 year model...)
