ye it has a oem style carbon bonnet..
axis hiro 19x9.5 wheels (theyre a U.S forged lightweight wheel, HUGE in the U.S)
it has that stance coz i wound the c/o up to get it on n off the truck without touching anything, dont worry, its gonna be slammed :P
Edited by MR MAD
https://www.sau.com.au/forums/topic/108007-delete/#findComment-1992682
custome colour, the wheels are 3500 with kumho tyres... i got john at tempe to bring them over for me.
they are 25 offset, no way id be able to put a 20mm spacer.. i like it as it is, coz ill be tuckin it wen the cars done :D
ill think about getting some 10mm ones tho, bolt on ones should do the trick ye? never used spacers so i dunno lol
https://www.sau.com.au/forums/topic/108007-delete/#findComment-1994273
Just looking at the pic 3/4 view from above, it seems like the wheels are a fair way in, but I could be wrong. I've got 25mm spacers on th FRONT of my car (hehehe Japanese stylez) just to get the wheels sitting right, so 10mm might do the trick. It looks sweet and well done on the EB aero mirrors :)
3 things I reckon every GT-R should: 1) get those rims flush with the bodywork, 2) forget about chrome anything 3) don't lower it *too* much.
https://www.sau.com.au/forums/topic/108007-delete/#findComment-1994296
nah i wont lower it too much but it has to be over the tyre... its jus me... i can fit my finger in between the guard n the tyre... theres maybe like 15mm clearance max before it will touch.. im gettin the spacers for nothing so no harm in trying ah?
https://www.sau.com.au/forums/topic/108007-delete/#findComment-1994304
    • Neg, the top one is actually for the front. The sizes are 18x10.5 +18 and 18x11 +32.   I measured many times but I'm sure I'll have problems as this is the thread for problems.
    • Just one thing; tapping tapered threads is tricky. Taps are always tapered and you would generally run it as far as you can, but with a tapered thread you have to stop much sooner otherwise the wide part of the taper will run in too far and you will have to thread the sensor in too far too as well (possible that it will never make a good seal) BTW nice wide wheels, I guess the top one is for the back!
    • Welp, good to know. Will have to wait awhile until steady hands with drills and taps are available. In other news, these just arrived! I will weigh them for posterity. Edit: 11kg each (or 10.9/11.1 depending on what my scale decides over multiple tests, the 18x11 don't seem to weigh noticeably any more than 10.5)
