my rubbers around my wndows should be black. instead they are kinda white. like stale chocolate lol
i remember readng sometime ago a thread on what to use to fix this..
someone said something about dying it... can someone tell me what product to use... if theres any thing i need to do b4 i apply the product.. and how much it will cost??
better yet, a link to the original thread would be prime
thanx in advance
SOMEONE...ANYONE????
Edited by bLaQ.bOi
I use Kitten interior protectant. Wipe it on with a piece of kitchen paper. Lasts a month or so if you don't handle it or get it super-wet.
I think anything like that (even armorall) will soak into the rubber for a band-aid fix.
Supercheap and many of those stores sell vinyl spray colourant. Used for plastic trims and the like. It can also be used on carpets and I think rubber. It is not a paint but a dye which actually gets into the surface. I've used it on interior and exterior trims and found that it does not come off. It also does not dry with a crust at all because it is just a dye. Worth looking into - awesome for dying plastics.
I've had great success with Meguiars SuperShine. It's for vinyl and rubber and is the first Meguiars product I've ever bought. Needless to say, when it turned my white window trims black and brought out the shine on my dash with the greasy Armourall touch I decided I shall definitely look at Meguiars in future.
Great product. It's a red bottle if you go looking.
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
