  • Replies 47
Posted Images
or do them black and get the same colour of the car and put it on a stick and dribble a criss cross pattern on them them clear them.... you could also do them black and hold an air blower over them and pour the cars colour in front of the air stream....this will splat the colour over them then clear them......another good trick is to marblize them...paint black and them again colour code them to the car....then while its wet rap them up in glad wrap....leave it on for 5 minutes then unwrap them and clear them
/\/\ orange and yellow would look better matched to a lighter blue imo, for navy abcent is spot on the money.
Is your bay the same colour of your car or black? If so maybe maych it to the colour of the car.
What colour will the fiddly bits be in the engine bay? U want all that stuff to match up to the colours also.
Anyways Abcents Nur spec gold gets my vote! :)
Sif need to 'do search'..
This thread ought to be moved to the right section like 'general maintenance' :laugh:
I agree with Bec ;) hehe.. tho its probably more suited for my car :D
That champagne is nice too.
Black is a good sleeper colour for you tho.. :)
Even the silver anodized look base coat you can get from supercheap looks cool on its own.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
