item:
bolt on upgrade turbo for RB25det, 350HP
description:
this turbo uses the factory nissan covers with a brand new 350hp Garrett ball bearing core, everything bolts up to factory mounting positions, only mod needed is to oil and water lines. covers have been cleaned and bead blasted.
price:
$1950
darra, brisbane
contact:
(07) 3375 3755, 0404841629, ask for ross or josh
https://www.sau.com.au/forums/topic/108709-rb25det-turbo-upgrade/
Seems a bit rich to me? 350HP @ $1950.
this turbo was built by turbo Australia and is the smallest of the upgrades that they perform. they do the same thing for the other stages but use a larger core for more HP, they go as high as 550HP for $2090. the one im selling is for a pretty much stock engine and is desighned to be a direct fit replacement for the stock ceramic turbo. due to garretts ball bearing desighn, and the use of a steel wheel, gives these turbo's the ability to get onto boost as quickly as the factory setup but the steel wheel lets you screw more boost out of them. so in fact it is a much better unit than the factory item.
also, the reason they call it the 350hp upgrade is beacause it uses a 350HP garrett core, just in case you didnt know.
Dyno graphs???
Also your "unoffical site" says $1,750 plus GST which equates to $1,925....
Has this been highflowed or just the core replaced???
Also 360 degree thrust bearing????
there are no dyno Graphs as yet but we are hoping to get some more feedback from a few customers that have recently fitted them.
i know what the website has as far as pricing goes but i miss typed it for this post so it is for sale for $1925 including GST.
this turbo has been highflowed, and garrett ball bearing cores do not have thrust bearings of any kind as the journal bearing are angular contact ball bearings.
Edited by tx240
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
    • Hi, is the HKS  Tower Bar still available ? negotiable ? 🤔
    • From there, it is really just test and assemble. Plug the adapter cables from the unit into the back of the screen, then the other side to the car harness. Don't forget all the other plugs too! Run the cables behind the unit and screw it back into place (4 screws) and you should now have 3 cables to run from the top screen to the android unit. I ran them along the DS of the other AV units in the gap between their backets and the console, and used some corrugated tubing on the sharp edges of the bracket so the wires were safe. Plug the centre console and lower screen in temporarily and turn the car to ACC, the AV should fire up as normal. Hold the back button for 3 sec and Android should appear on the top screen. You need to set the input to Aux for audio (more on that later). I put the unit under the AC duct in the centre console, with the wifi antenna on top of the AC duct near the shifter, the bluetooth antenna on the AC duct under the centre console The GPS unit on top of the DS to AC duct; they all seem to work OK there are are out of the way. Neat cable routing is a pain. For the drive recorder I mounted it near the rear view mirror and run the cable in the headlining, across the a pillar and then down the inside of the a pillar seal to the DS lower dash. From there it goes across and to one USB input for the unit. The second USB input is attached to the ECUtec OBD dongle and the 3rd goes to the USB bulkhead connected I added in the centre console. This is how the centre console looks "tidied" up Note I didn't install the provided speaker, didn't use the 2.5mm IPod in line or the piggyback loom for the Ipod or change any DIP switches; they seem to only be required if you need to use the Ipod input rather than the AUX input. That's it, install done, I'll follow up with a separate post on how the unit works, but in summary it retains all factory functions and inputs (so I still use my phone to the car for calls), reverse still works like factory etc.
    • Place the new daughterboard in the case and mount it using the 3 small black rivets provided, and reconnect the 3 factory ribbon cables to the new board Then, use the 3 piggyback cables from the daughterboard into the factory board on top (there are stand offs in the case to keep them apart. and remember to reconnect the antenna and rear cover fan wires. 1 screw to hold the motherboard in place. Before closing the case, make a hole in the sticker covering a hole in the case and run the cable for the android unit into the plug there. The video forgot this step, so did I, so will you probably. Then redo the 4 screws on back, 2 each top and bottom, 3 each side and put the 2 brackets back on.....all ready to go and not that tricky really.
