  • Replies 106
Posted Images
Any one know the amount of colour coats and then clear coats on the GMG R32 GTR out of the factory? I know the colour is Nissan's KH2, but I have a body kit in mind and want it fitted after spraying and also want the bonnet resprayed to match the cars exact colour.
Also, what would it cost to get a kit + bonnet resprayed? I will probably take my car to damage control because I have some rust that I want them to clean up for me as well.
https://www.sau.com.au/forums/topic/108736-re-spray/page/5/#findComment-2317132
  • 1 month later...
5500 it is going to cost me to get my car dont by fibre vision, going with black, red pearl, and gold glitter. i guess i am paying most of it by labour, cause of the colour i am after and this is just the out side of ther car
https://www.sau.com.au/forums/topic/108736-re-spray/page/5/#findComment-2446514
thats reasonably 'cheap' for what you are having done.
not having the door seals/engine bay/etc etc done?
i was going to get mine done in calsonic/bionic blue, before i decided to sell it, was looking at about $7,000 for that, but i *know* that would have been a good job.
https://www.sau.com.au/forums/topic/108736-re-spray/page/5/#findComment-2446690
  • 3 weeks later...
umm depending if you have had any past experiance and how confident you are. could do the prep work your self, such as getting the car primed up and everything, takes a while and your car while look funny for a while but it really cuts down man hours therefor taking a huge chunk out of the cost,
me and my mate worked on priming his hilux mini truck every weekend, took a while but that was because we were shaving door handles etc.
it is time consuming but the longer you take to get the primer on there right and sanding it back so its 100 percent perfect the better finish you will get.
this is my mates car preped and when he got it sprayed >_< hope this helps, if it doesnt then shoot me >_<
https://www.sau.com.au/forums/topic/108736-re-spray/page/5/#findComment-2500336
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
    • The downside of this is when you try to track the car, as soon as you hit ABS you get introduced to a unbled system. I want to avoid this. I do not want to bleed/flush/jack up the car twice just to bleed the f**kin car.
    • But again, the engineers said your cast aluminium would be fine based on the load that would be stretching that section. Same load stretching the bolts in a flex (not the twist), with a much smaller cross sectional area than the original part you've broken. It's why you'd need to be using higher strength bolts, but that's just making up for the strength you lose with less area...
    • I am truly amazed someone on this planet was able to cycle the pump using a scan tool. I've always ghetto cycled them on Nissan 90s shit boxes by slamming the brakes and pulling the handbrake to agitate the rear wheels enough to cause a speed difference
