Just a note: Lowering the car won't affect what diameter wheels you can put on because in the end you should have the same rolling diameter to keep your speedo accurate.
Iif you lowered the car and it's fine with the stock wheels, then you should be able to fit any other diameter wheel as long as the rolling diameter (wheel + tyre) is the same.
Lowering does affect how wide your wheels can be though.
my whale with 20 x 8.5" wheels and 225/30 tyres.
doesnt rub at all.
lowered with Kei Office coilovers.
as you can see, i would presume fitting 17s and slamming on its guts wouldnt be of any issue as long as the rim offset is ok.
Edited by _8OO5TED_
only time it has rubbed is when the car is on an angle and im turning sharply....
otherwise, its perfect :P
also, removed guard lining to make some extra room too.
was hoping to go lower, but my front tyres were running on the wiring loom that ran through the front guard lining so i cant.
Edited by _8OO5TED_
Did you guys need to get your gaurds rolled or anything like that when you lowered? if my 33s been lowered by previous owner its still pretty close to stock height and with my momo 17s on it the tyres rub sometimes when turning sharp, anyone know where to get gaurds rolled in vic?Id like to go lower.
Also Ive come across a few low king springs for 33s for sale, what kind of ride could I expect if I had these fitted?
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
