In the hope to o/c my E8400 some more (4.4Ghz+ air cooled), I've upgrade my heatsink (Xigmatek HDT-S1283) and case to a full tower (CoolerMaster HAF 932). The case is awesome...it has 3x23cm fans (or supports 7x12cm) + 14cm rear exhaust, also, for when I try my hand at water cooling latter down the track it can support 2 PSU's and 3 fan radiator + 2 fan rad + 1 fan rad = :P:D
hahah awesome Patrick I've been thinking about a 4850 gfx card cause its mid rang bang for buck and i dont have a good enough CPU to even make full use of its power but I'm sure its better than a x1900xtx
thats why u have 2 8600's like me xD
I had 8600gts. not bad.
but the new 9800gt runs cod4 perfect. everything high. high res too.
crysis runs smooth too on high. very happy. and it doesnt cost the world either.
  • 3 weeks later...
I'd doubt they'd release it mid-year....if they were smart it will most likely be closer to the Xmas season plus will give more opportunity for other programmers to make their software compatible.
Yeah I'll prob try it out...good thing Vista has disk-part otherwise loading this for a tri-boot would be a pain.
first impressions of win 7...
u cant set the start menu to the old skool style... have to use the homosexual spec new one. and the aero shake thing is pretty cool.
other than that it seems to me that they have made vista, more "vista" does not wanna let u think for urself
:down:
    • If there's enough meat in the housing where you want to put the M12 adapter, then do it, but be aware that if/when you f**k that up you'll probably be repairing it before doing anything else. I'd just drill it out and tap ina 1/4" thread. No need for rocket surgery when the next most obvious thing will do. You could throw a 1/4 x 1/8 bush in there and use the same fitting you intended to use.
    • Is the only issue that the oil catch can is getting filled on hard runs? I'd be thinking more about oil control issues rather then the head lifting, especially as you aren't seeing spiking in the coolant pressure.  Do you need restrictors in the head, or better drains from the head? Does the sump need venting to the catch can?
    • Tried to make 1/8npt threads into compressor house of the turbo for my EBC. Threads got fu#ked and ended up with and elongated hole, so I do have good amount and nice threads 90% of the hole but 10% I only had 1-2threads there and rest of it is flush on that side of the hole.. So my idea is to do M12 x 1.25 to AN4 with braided lines instead of 1/8npt to 4mm vacuum silicone hose.  and hopefully get a better thread. M12 is quite big and AN4 is a little bit bigger than 4mm (4.9mm inner diameter braided PTFE hose). but this should work. Thoughts? Otherwise I will weld and adapter onto the turbo.
    • Looks great, I hope everything is working well after all that time!
