In the hope to o/c my E8400 some more (4.4Ghz+ air cooled), I've upgrade my heatsink (Xigmatek HDT-S1283) and case to a full tower (CoolerMaster HAF 932). The case is awesome...it has 3x23cm fans (or supports 7x12cm) + 14cm rear exhaust, also, for when I try my hand at water cooling latter down the track it can support 2 PSU's and 3 fan radiator + 2 fan rad + 1 fan rad = :P:D
hahah awesome Patrick I've been thinking about a 4850 gfx card cause its mid rang bang for buck and i dont have a good enough CPU to even make full use of its power but I'm sure its better than a x1900xtx
thats why u have 2 8600's like me xD
I had 8600gts. not bad.
but the new 9800gt runs cod4 perfect. everything high. high res too.
crysis runs smooth too on high. very happy. and it doesnt cost the world either.
  • 3 weeks later...
I'd doubt they'd release it mid-year....if they were smart it will most likely be closer to the Xmas season plus will give more opportunity for other programmers to make their software compatible.
Yeah I'll prob try it out...good thing Vista has disk-part otherwise loading this for a tri-boot would be a pain.
first impressions of win 7...
u cant set the start menu to the old skool style... have to use the homosexual spec new one. and the aero shake thing is pretty cool.
other than that it seems to me that they have made vista, more "vista" does not wanna let u think for urself
:down:
    • Oof, I don't think you should add it up like that! It sounds much better at $21 per issue. I don't see any problem there if you enjoy the process and the result. I really like the magazine side of it with all the little tidbits and facts. Also, if anything, these forums are all about spending unreasonable amounts of money on hobbys. I wouldn't call it a self-help group because people generally suggest to spend more
    • I put another 2 layers of putty and still getting pinholes. Think i might either try the filler first then putty or just leave the little specs of guidecoat as is and get primer to fill it in. I think i misread understood what you said above when you said my glazing putty wasnt enough for the size of the area. I thought you meant 1 coat and i needed to. But i think what you meant was that I needed filler first? I also went a bit too far out the repair area as my spreader is a bit large.
    • You do sorta. In my instance they were little specs and I didn't even think they'd be pin holes but it all makes sense now. Huge learnings there!
    • Ah ok that makes sense and it's where i think i went wrong because before when i put filler then putty, i didn't have this issue and now i do because i only put 1 coat of putty. Thanks for that heaps man, it's a good way to put it! With my putty I'm using the dolphin glaze which i just saw it says finishing putty lol. I didnt put filler cause it was a shallow area but i see what you're saying. Also I'm an idiot, i just realised that while i put new putty there are pinholes! I probably saw it before and ignored it for whatever reason. I think because i thought putty is used to fill pin holes that itself wont make pinholes but that's incorrect of course. I feel silly now haha. ok I think I know what to do next. Thanks man!
    • Yes correct, the guide coat is showing low spots, in this instance the low spots are pin holes. I agree wetting the areas makes it more visible (but you can see it's there before you wet it as well lol).  Once the panel is flat, the guide coat will be gone
