I am running a copy of Windows 7 in VMware under Vista x64. Runs really well with 1gb assigned.
If you want to use the full 4gb simply download Windows 7 x64 :banana:
hows the driver situation for x64 these days? I installed x64 xp pro 4 years ago and was annoyed that a load of stuff didnt have drivers (and i have reasonably modern hardware).... i switched back to 32 bit 2 days later and havent touched it since, however i will be upgrading in a few months time and its worth thinking about
-D
-D
Now issues. Now. :laugh: But as with everything it depends on the hardware. Mines a fairly basic setup. Intel cpu, intel chipset m/board, nvidia 8x vid card, 2 large hard drives, dvdrom for the Wii and a nice pioneer burner.
Windows is rock solid I don't have any issues with games programs.
Like yourself when it was first released pre-sp1 I tried x64 and it was crap, wasn't too keen on vista x86 back then due to 2gb not running all that flash when you throw a decent game and vmware at it so I dropped back to XP. Sp1 came around and decided to install x64; felt slow so threw another 2 gb at it.
x64 does need 4gb other wise it feels a little chuggy.
Running 2gb with vista felt slower than xp with 2gb. Vista with 4gb is noticeably snappier than xp.
Im looking at getting a laptop soon for nistune ecu tune, internet, gaming and watching dvd's. Iv hade a look around and most places i go to say Acer is the brand to go with, is this true?
Dave
I wouldn't say so, few family members own then, they're pretty dodgey. Toshiba make some nice cheap ones, and asus laptops aren't too bad.
Cheers for that iv herd the same about Acer aswell just wasnt sure if it was true. I just rang same places and they have toshibia laptops starting from $1100 so il go see and hopfuly i come back with somthing.
I got the toshiba satellite A300
15.4 screen
Vista
Intel® Core2 Duo P7450@ 2.13GHz
2.00 GB
selling price was $1799 but got them down to $1699 with a Belkin case and belkin cordless mouse
$200 over the budget but still pretty happy
at work we use:
Desktops: HP7800's...core 2, 2 GB RAM, 180GB HDD and i reackon they are awesome units
Laptops: Dell Lattitude D830....core 2, 2GB RAM 120GB HDD...slightly heavy laptop but doesnt give any hassles
just thought i would put it out there u knw
Dave
I have an Asus EEE 901 for that exact purpose - works excellent. Need a bigger SSD but thats coming soon... theyre dead cheap too and fit in the glovebox
-D
i am a big fan of those eeepc's
if your are student then they are perfect
compact in size and are not too bad in performace
with just the basics
I've only encountered two minor issues. One is the size of the primary SSD (4gb) and the other is the speed of the secondary (either 8 or 16gb depending if u get the linux or windows version).
I ran out of space for my windows install on the 4gb and have software which needs to be ran off the boot drive. When I switched it to the 8gb ssd, the SSD was just too damn slow (the write times are 3-4 times as long which makes all the difference)...
So I've put Fedora 10 on the 4gb, XP is on the 8gb and I'll be getting a runcore 32gb m-pci SSD to replace the 8 gigger. They actually make very fast SSD's, faster than the stock 4gb unit. Couple that with the 2 gigs of ram I've put in there, and it should fly.
Unit works beautifully with my bluetooth mouse and nextG bluetooth phone as a modem. Runs fedora with compiz fusion very very nicely and has around 4.5 hours of battery life at constant use. I've managed to make mine last all day by changing the APCI settings.
It also fits in the r32 glovebox, which is where I have the consult port and 12v power to the laptop wired. Makes it very very easy to port around as it gets charged in the glovebox when I'm driving...
-D
i was thinking of making a custom glove box setup with the eeepc controlling my audio / video and the rest
would be a mental setup as i could have the glove box open and use the eepc and shit like that
Those are the first generation 701's. They arent good value for money. They have a 7" screen and a paltry 800mhz CPU.
The 901's were the first to bring in the Intel Atom chipset - Dual core 1.6ghz with integrated 945 chipset for video (it complies with vista's rendering standards). The 901's also have more battery life and a 9" screen, and some versions are coming out soon with integrated HSDPA (Next G data) modems built into them.
Krishy, it wouldn't work nicely for AV, esp not in the glovebox - if you want to do that, a carputer is still the best option, esp if you get it with an in-dash touchscreen.... EEE's are great for what they are, but they still have undersized keyboards which give most people hassles, and I'm sorry to say that the trackpad isnt great either - which was the main reason I bought the bluetooth mouse...
They also have the ability to run the EEE-TV usb DVT-B digital tuner - I've got one and it works great, provided you're in range and have a decent antenna...
Personally, I wouldn't buy anything without the Intel Atom chipset... the 901 isnt slow, but you wouldnt want to go much slower - esp if you don't intend on replacing the secondary SSD with a faster replacement.
-D
    • perhaps i should have mentioned, I plugged the unit in before i handed over to the electronics repair shop to see what damaged had been caused and the unit worked (ac controls, rear demister etc) bar the lights behind the lcd. i would assume that the diode was only to control lighting and didnt harm anything else i got the unit back from the electronics repair shop and all is well (to a point). The lights are back on and ac controls are working. im still paranoid as i beleive the repairer just put in any zener diode he could find and admitted asking chatgpt if its compatible   i do however have another issue... sometimes when i turn the ignition on, the climate control unit now goes through a diagnostics procedure which normally occurs when you disconnect and reconnect but this may be due to the below   to top everything off, and feel free to shoot me as im just about to do it myself anyway, while i was checking the newly repaired board by plugging in the climate control unit bare without the housing, i believe i may have shorted it on the headunit surround. Climate control unit still works but now the keyless entry doesnt work along with the dome light not turning on when you open the door. to add to this tricky situation, when you start the car and remove the key ( i have a turbo timer so car remains on) the keyless entry works. the dome light also works when you switch to the on position. fuses were checked and all ok ive deduced that the short somehow has messed with the smart entry control module as that is what controls the keyless entry and dome light on door opening   you guys wouldnt happen to have any experience with that topic lmao... im only laughing as its all i can do right now my self diagnosed adhd always gets me in a situation as i have no patience and want to get everything done in shortest amount of time as possible often ignoring crucial steps such as disconnecting battery when stuffing around with electronics or even placing a simple rag over the metallic headunit surround when placing a live pcb board on top of it   FML
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
