there is a new generation of eeepc's coming out soon called the netbooks
http://www.news.com.au/technology/story/0,...5014239,00.html
that article is a load of shite
EEE's >ARE< netbooks.
-D
Did you two read the article?? :( There's no mention of the next generation Asus Eee PC, rather it was just stating that the Eee PC's was the orignator for the term "netbooks".
"The Eee PC is where the netbook buzz began and remains the lowest- cost entry point...."
lol now that is some real geeky shit right there ^^^^
even geekier is actually sitting up waiting for it to happen.
and worse yet, writing a php script that counted down. lolz
im looking at getting a desktop comp soonish to replace the laptop. im not an uber l337 gamer so i dont want anything too fancy, just something thats gonna handle online games like runescape in HD.
was thinking something like this with the AMD AM2 Athlon x2 5200+. Thoughts and possible upgrades?
    • he bridged the 2 pipes together in 2 spots. Making a H pipe. i'll get a photo and post it tomorrow
    • The spray cans were in the "Kiln" room whilst I was preping the parts,  so probably around 2 hours to get them warmed up, the kiln room has 3 small ovens running at 100°c, 3 medium sized ovens running 100°c, and the large one I used running at 80°c, the room itself was about 28°c, I also spent a bit of time taping up the parts in the room as well, and by the time I was done I would assume that the parts were around that 28°c As for power, I expect a couple of Killerwasps up high would be achievable with the current mods, I'm still running the MZR 2.0 intake and throttle body, and there is a slight mismatch with the 2.0 intake (smaller) and 2.5 intake ports (larger) on the head, this intake is matched and specifically designed to fix this issue with the ports mismatch, the throttle body is also a couple of mm larger, OEM is 65mm, the Bosch is 68mm In the end it will look "prettier" than the molded plastic thing that is the OEM MZR 2.0 intake As for the LSD, it's the OEM Torsen which works fine for what I use the car for, plus, basically no maintenance apart from the occasional oil change
    • I was at Tunehouse in Marrickville (great team over there really know their VR's) , and I spotted this Very clean R35.
    • Mate , I have the same issue right now with the exhaust noise , if you can tell me what your local guy did , I'll talk to my guys and see if they can do the same. Power is good but it just too loud when put it down.
