but everything I ever buy is overkill, lol.
well have i got a new car for you.....
I can finally work on models with out the PC freezing every 2 mins when you click on a pixel
previously the 3d work was around 50K poly now working on 200-300K poly models
which look sooo much better when doing 19,000 X 10,000 renders :cheers:
Edited by Whiplash
hi all.just wondering what you all use as a media player on ur PC?
i use VLC, love the layout and most things about it. the issue i have is it freezes over the lan, and also on my desktop... i have used the googleizer and tried the things suggested there, increasing the buffer helped a lot, but i still get the freezes :)
in the past i was a big fan of media player classic, but i find the playlist a bit clunky so i have been persisting with VLC.
does anyone out there use anything else that is worth a shot?
...::edit::...
my os is win 7 ultimate
Downloading VB 2010 Express at the moment (http://www.microsoft.com/express/Downloads...10-Visual-Basic). I remember using this years ago, I'm willing to have another play around with it to see what it can do.
Carl give ZPlayer a try ..... I use if for watching DivX movie/tv dls and it works a treat. Seems to handle different file types and codes better when doing fullscreen than all other apps I have tried. I also use the CCCP ffdshow/codec pack - has always been great.
guys I've got an old Benq laptop that does pretty much everything that I need for work.
Except for a little more speed, I'd be happy to stick with it for another year or 2.
Thing is, it has an IDE HDD (not a SATA) so going to an SSD to improve performance is pretty much out of the equation.
Anyone here ever configured an SSD into an IDE connection?
Depends on if you have 1.8 or 2.5" PATA drive;
http://www.solidstatecentral.com.au/store/...8b79bfa4f8f3fc6
I've bought runcore SSD"s off these blokes before and used them as upgraded drives in EEE's. Work very well.
-D
The transfer rate of IDE wont give you any decent performance with a SSD over the normal drive. But if you are keen on the SSD idea still, you could use an IDE to Compact Flash converter.
this is what I'm worried about........if the controller is the limiting factor then it's probably pointless spending $300 - $400 to gain little if any speed at all......better off puting it towards another laptop maybe.
This is what's in it now:
WD1600BEVE Scorpion Blue
160Gb 8 Mb cache 5400rpm 2.5" PATA
the transfer rate will be a sustained rate rather than a variable rate and there will be no seek or write latency
you'll notice the difference. put it this way, ATA supports up to 133mhz bandwidth, SATA is 150... SATAII 300... etc
diff between sata1 and ide is not much at all - esp since your drive is a 5400rpm its slow as dogs balls...
the other benefit is the wd probably runs 5watts when seeking and reading, the ssd will be about 0.1watt peak. You'll save a fair bit of battery with an SSD..
-D
you reckon the extra minimal performance difference is worth the dosh though?
Wish I had some figures or comparisons between my drive and an SSD on an EIDE controller
for the price? frankly no.
buy a new laptop with an ssd already in it, if you want the bang for buck
however ssds will speed up ur system, including outdated ide buses
-D
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
    • Yes they do. For some maybe. But for those used the most by abusers, ie Skylines, the numbers are known. The stock eyebrow height for R32/3 Skylines is about 365/375mm or thereabouts. The minimum such heights are recorded in adjacent columns in the database.
    • Hmmm, interesting. Makes me wonder whether there is bias as well. It's the cheapest fuel, so it is used for all kinds of ill-maintained shitboxes which are bound to have issues regardless. Nicer cars tend to require higher octane rated fuel and can't use it anyway. FWIW, the official NSW E10 facts page is decent.
