for the last 6 months ive had a 2535 on my series 1 rb25 running 15psi and putting out 231kw.
the car is punchy and makes full boost by 3200rpm but i want it to feel more aggressive and come on boost more rapidly and maybe earlier. (it feels like a vtec, very safe tune)
I think these are my options:
*bigger 550cc injectors and run a more aggresive tune
*exhaust cam gear
*split dump pipe
does anyone else have any ideas how i can make my car more aggressive out of the corners?
I'm a sook, i cant handle any lag
https://www.sau.com.au/forums/topic/108919-hitting-boost-quicker/
Hahah 2535 Lag?
I loved the 2535 on my RB25, it hauled ass!
I don't know about yours but mine came on boost very suddenly and sharply!
I had EBC, Split dump, FMIC and SAFC-II :P
ps I would go for the split dump - while running stock dump with my 2535 it was woeful! - Best $$$ spent was on Split dump
Seems to be a recurring theme with the rb20 and rb25, this lag problem.
With how cheap turbos and exhaust manifolds are getting nowadays, I wonder if a twin turbo kit could be mass produced with two tiny turbos to virtually eliminate all lag.
Just a thought.
3inch turbo back exhaust, split dump setup
aftermarket engine management (powerfc)
injectors wont help at all
a pair of tomei cam's
a good cold air intake
make sure you dont have a big stupid 800x400 FMIC
ive already tuned the first 8X8 cells in a very similar fashion, it made a difference to economy and the transition between off-boost and coming on.
that table u have displayed paulr33 looks like the stock ignition table??
will an exhaust cam gear make the mid range much more punchy???
Edited by reflex
well if you've done the ign timing then theres probably not a great deal more you can do. i dont think cam gears will give you 2 tenths of fark all. yeah i posted the stock ign table to see if you were still running that (some tuners don't touch the low area).
wind that boost up!!!!! you wont even have time to look at the tacho if you wind about 17 - 18psi into the 2535... the difference on mine was amazing from 14 psi to 18psi....
The power was very smooth and progressive before but now you can feel a strong surge of power then BANG!!! she pulls and pulls!! i love it!
if your in my area, ill take you for a spin if you like or if your at then next vic event??
If your wastegate was opening at idle, would explain why you're disappointed with power output!
My suggestion, after reading that comment, is to take ur ride to a mechanic and get it fully inspected, to make sure everything is running right. No use flogging a dead horse.
a good way to see if thats the case or not is to
unplug the actuator line and do a dyno run (be sure to watch boost) and immediately back off when target boost is reached, cos you will be in unlimited boost mode.
then do another dyno run with the actuator connected again like normal and let it run. then overlay the two dyno runs plotting only boost and see if they are the same. if they arent then the actuator is leaking or opening too early
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
