Hi folks,
Long time no hear - right ??
What's been happening ?? Buster, have you cracked an 8 yet mate ?
Duncan, hows the Yellow dildo going ?
Maj - is your car still in one piece ?
I've been missing you all !
Well, about me -
I quit my job at Telstra and now (believe it or not) I am a Personal Trainer. I can hear you all laughing now - How did that fat bastard become a Personal Trainer ? Well, lose 15kgs for starters - Study hard, get qualified and buy a PT Franchise ! that's what I did !
And I am loving it - although the pay is about 4 times not as good as IT, the stress is less ! (Getting up at 4:00am in the morning is not that crash hot)
What else, Oh yeah - the girly has moved in - BOY what an eye opener that is. Shit man, I can't do a thing right, my whole place has been redecorated, the dog nearly got kicked out - Sheeeze - the the things you do !
Moving on to my car - Well, still have the Paj - it's a warrior ! haha BUT . I need something zippy. Thought about putting a V8 in the Paj, but it just wouldn't do !
So - since my budget is small - VERY VERY small - What do you reckon ?
I saw a Peugot 205GTI for $1900 the other day - looked OK - Then I got to thinking about options:
Corida
Starion
Mini
Dato 1600
Swift GTI
What do ya think ?? I want something zippy for streets.
This is how bad it is ...... I hired a Triton Ute the other day - and I though it as a rocket ship. I drove my sisters auto Mirage - and I though it was a go cart !
I NEED A FASTER CAR !!
Help me - I am going insane ! !!
Cheers
https://www.sau.com.au/forums/topic/108926-what-happend-to-b-man/
good to hear from ya brendan
wow, talk about a new path... thats friggin awesome, you saw the opportunity for a change and it sounds like it was the best thing for you. i'm impressed and envious of your courage :)
hehe chicks, know what your saying ;)
couldnt be happier for ya man
:D <--- icon probably wont work but you get the idea
*EDIT* hah it worked ^^
Jimbo
go the Dato I say! :D
seriously though, easy to work on cheap insurance and proven easy upgades, cant go wrong... i want one!
and with the rest, life is full of sacrifices, but you should only make them if you really want what your after (the girl). So I say as long as your happy, then the redecorations and shit are nothing in comparison to happiness. And congrats on the cool life change.
meh....kaboom its now called d-manning.
Thank god you lost the girl not the dog :D And ti goes to show theres nothing like changing what you are doing for a breath of fresh air.
Anyway. Buy a 4 door gts4 i reckon
Corida
Starion
Mini
Dato 1600
Swift GTI
Cheers
Good to see you're still alive - heaps of the original SDU/SAU crew are either missing or just don't post anywhere near as much as they used to...
Anyway, onto the car: WTF is a Corida? Is it as small as a Corolla but with the luxury (and RWD) of a Cressida? If it is, I say go for that and drop a 1JZ-GTE or 1UZ-FE into it for giggles...
Cheers,
Nick T.
What happened to B-Man....well....
First he tried to save Tibet and failed...
Then he tried to save Van Ngyuen and failed...
Then he thought...If i can't save the world...I may as well save myself.
And...so far...he's succeeded!!
Well done with your new career Brendan...Keep it up and best of luck!
    • I neglected to respond to this previously. Get it up to 100 psi, and then you'll be OK.
    • I agree with everything else, except (and I'm rethinking this as it wasn't setup how my brain first though) if the sensor is at the end of a hose which is how it has been recommended to isolate it from vibrations, then if that line had a small hole in, I could foresee potentially (not a fluid dynamic specialist) the ability for it to see a lower pressure at the sensor. But thinking through, said sensor was in the actual block, HOWEVER it was also the sensor itself that broke, so oil pressure may not have been fully reaching the sensor still. So I'm still in my same theory.   However, I 100% would be saying COOL THE OIL DOWN if it's at 125c. That would be an epic concern of mine.   Im now thinking as you did Brad that the knock detection is likely due to the bearings giving a bit more noise as pressure dropped away. Kinkstah, drop your oil, and get a sample of it (as you're draining it) and send it off for analysis.
    • I myself AM TOTALLY UNPREPARED TO BELIEVE that the load is higher on the track than on the dyno. If it is not happening on the dyno, I cannot see it happening on the track. The difference you are seeing is because it is hot on the track, and I am pretty sure your tuner is not belting the crap out of it on teh dyno when it starts to get hot. The only way that being hot on the track can lead to real ping, that I can think of, is if you are getting more oil (from mist in the inlet tract, or going up past the oil control rings) reducing the effective octane rating of the fuel and causing ping that way. Yeah, nah. Look at this graph which I will helpfully show you zoomed back in. As an engineer, I look at the difference in viscocity at (in your case, 125°C) and say "they're all the same number". Even though those lines are not completely collapsed down onto each other, the oil grades you are talking about (40, 50 and 60) are teh top three lines (150, 220 and 320) and as far as I am concerned, there is not enough difference between them at that temperature to be meaningful. The viscosity of 60 at 125°C is teh same as 40 at 100°C. You should not operate it under high load at high temperature. That is purely because the only way they can achieve their emissions numbers is with thin-arse oil in it, so they have to tell you to put thin oil in it for the street. They know that no-one can drive the car & engine hard enough on the street to reach the operating regime that demands the actual correct oil that the engine needs on the track. And so they tell you to put that oil in for the track. Find a way to get more air into it, or, more likely, out of it. Or add a water spray for when it's hot. Or something.   As to the leak --- a small leak that cannot cause near catastrophic volume loss in a few seconds cannot cause a low pressure condition in the engine. If the leak is large enough to drop oil pressure, then you will only get one or two shots at it before the sump is drained.
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
