How long is the piece of string?
What turbo?
What state if the motor in?
looong list
Anyone can put a big turbo on and make 500rwkw.
Doesnt mean you can call that motor reliable
Yeh I know its a preety vauge qeustion Im sourceing a new engine taking my time so it will be a good condition engine, for my 33 GTST and stocking up on goodies to add on in the mean time all I want to know is whats the biggest turbo you can use if you change to sard injectors,N1oil pump,N1water pump, high mount manifold, metal head gasket,FMIC,radiator breather,air flow meter,oil cooler,oil catch can,powerfc with boost controller,fuel regulator,bosch fuel pump,BTMBL split front dump and 3" zorst etc etc... but leave the internals stock?
https://www.sau.com.au/forums/topic/108975-turbo-upgrade/#findComment-2007246
your plan is very flawed and lacks some important parts;
1) how much do you have to spend
2) what is the car being built for
3) what is your power goal
no need for n1 water pump unless going on a race track all the time (its not suited for street)
no need for n1 oil unless going on a race track all the time (its not suited for street)
high mount manifold is useless
what airflow meter?
why sard injectors?
what clutch?
what cold air intake?
without knowing anything else its very hard to tell you what parts etc.
https://www.sau.com.au/forums/topic/108975-turbo-upgrade/#findComment-2007260
what airflow meter?
why sard injectors?
what clutch?
As youve more than likely allready figured out im pretty new to all this and since im putting in a new engine I just thought Id buy new everything so just went on just jap and nismo and started listing parts and thought might aswell buy the best, what power can you safely push an unopened rb25det to?
https://www.sau.com.au/forums/topic/108975-turbo-upgrade/#findComment-2007279
After buying the engine and getting it in i was looking at spending 6-7k but not in any hurry thats why im on here asking questions, im not planning on draging/drifting or raceing anytime soon I just want a quik car with a nice kw rating something thatll show my mates up in there clubsports and XRs :laugh:
https://www.sau.com.au/forums/topic/108975-turbo-upgrade/#findComment-2007285
max power of stock internals is around 270rwkw
any more and your starting to risk safety
What mods would you suggest to push it up to around that, thats the kind of figure I was hoping for but didnt really want to have to rebuild
ps-thanks for this mate lotta blokes just get on here and treat us newbs like idiots
https://www.sau.com.au/forums/topic/108975-turbo-upgrade/#findComment-2007289
rb25det
+ heavy duty clutch $1200 fitted
+ apexi powerfc + boost kit $1500 tuned
+ nismo 550cc injectors $1000 fitted
+ z32 airflow meter $450 fitted
+ gtr33 fmic $1000 fitted with pipework
+ 3" turbo back batbml exhaust and 3" hiflow cat $1500 fitted
+ good cold air intake $400 fitted
+ gtr33 fuel pump $300 fitted
+ hks gt-rs $2800 fitted
+ nismo fuel regulator $300 fitted
+ set of good 255 tyres $500 fitted
total; $10,650 with conservative labour rates
then you should really look at brake and suspension upgrades.
with that amount of power, estimated 260rwkw at 1.3bar it will spin and carry on sideways and insist on spinning as much as it can so you really need to work on the suspension to make it more enjoyable, safe and allow it the best chance to get the power down.
https://www.sau.com.au/forums/topic/108975-turbo-upgrade/#findComment-2007299
' date='10 Mar 2006, 12:11 AM' post='2007280']
hey dude :laugh:
why are you buying a new engine what is wrong with the current one in ur r33 now?
looks like when I had it serviced some cock jockey forgot to screw the plugs back in, drove fine for about a month and them blew the thread out of no1 burnt the coils and dropped who nows what into the engine, I could pull the head off get it machined put in a hellicoil and put it all back together again but whos to say thats the only problem and then Ive spent more than half the money Id pay for a whole engine replacement so I though wtf not? first I was thinking of the 25/30 build but thats out of budget for me :laugh:
https://www.sau.com.au/forums/topic/108975-turbo-upgrade/#findComment-2007305
Manifold - $1200
ECU - $1100-$1800
Tuning - $400
Turbo - $1800
Injectors - $900
AFM (maybe) - $350
Ext Gate (maybe) - $700
I/C + Piping - $600
Radiator - $660
Fuel Pump - $300
FPR (not needed) - $150
Catch Can - $250
Exhaust - $700-$1100
Your well over the 6-7k budget dude. You at 9k before you even start paying for labour which will put you into the 11k or more region
Those prices are retail.
I think your best bet is to settle with a stock turbo for the time being.
Get all the bits save for the turbo/injectors etc etc as you are double your budget before you even start.
Who cares about showing off to your mates. Going from 150rwkw to 270rwkw isnt a walk in the park. Can be the death of you quite easily
1) Have a read of the RB25 sticky thread
2) Have a search on the turbos used (for more detailed threads) and then go from there.
3) All this has been done pretty well before as 250rwkw is common goals.
https://www.sau.com.au/forums/topic/108975-turbo-upgrade/#findComment-2007306
rb25det
.got the exedy heavy clutch in allready,BTMBL and 3"exhaust within the fortnight, the sard injectors are 550cc nismo better?FMIC next week,powerfc and boost control about a month, think I can get the turbo bit cheaper than that through someone,where could I get cold air intake/fuel pump/airflow meter?
https://www.sau.com.au/forums/topic/108975-turbo-upgrade/#findComment-2007312
hey i just add my 2cents, i just bought this stuff for my rb25
-hks gt2835 pro s kit (400ps) - $3500
-Nismo 740cc Injectors - $1000
-Apexi Pfc - $1000
-Z32 AFM - $300
=$5700
i already have ebc,fuelpump,clutch,coilovers,clutch etc etc
then you got to add labour etc etc...
6-7k = not going to get you much :S
https://www.sau.com.au/forums/topic/108975-turbo-upgrade/#findComment-2007320
For SARD - search, the problems with the RB25 fuel rail are well documented by everyone who's tried using them ;)
end of the day, dont get em
im running sard 550cc's and had no issues with them ..
can be more tricky to install.. but once in correctly,. no issues
https://www.sau.com.au/forums/topic/108975-turbo-upgrade/#findComment-2007425
I just want a quik car with a nice kw rating something thatll show my mates up in there clubsports and XRs :)
:P
Not another one!!!!
I know a cheaper way mate.
spend some of your money on a corolla.
then spend the rest of your $7K or so on steroids, hit the gym, get fcuking massive and when any of your xr/clubadore mates says anything about your corolla, go nuts, rip their arms off, and beat them to death with them.
https://www.sau.com.au/forums/topic/108975-turbo-upgrade/#findComment-2007972
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
