hey guys and girls,
just wondering about the different specs of the variuos GTR's around. could someone shed some light on them cos it seems everyone has a different opinion of them.
i've been told the V-Specs have brembos (and different wheels if still fitted), and the Nismo versions have no ABS, no rear wiper, ~60kg lighter, and different bodykit (nostrils, bonnet and boot lips, skirts). Are there any other differences? because i've read that R33 V Specs have more aggressive diffs and suspension?
reason i'm asking is because i'm trying to tell if it is worth the extra spend for the car as opposed to getting new brakes (and etc.) for a normal GTR?
i'm new to forums so you'll have to forgive me if i'm in the wrong section.
Cheers, see you on the road...
https://www.sau.com.au/forums/topic/109045-r32-gtr-vs-v-spec-vs-nismo-edition/
best bet is to do a search of the forums & you should find boundless info on the subject.
Basically, no it isn't worth the extra spend to buy a V-spec GT-R or a Nismo edition unless that is what you really want for its own sake. The brake upgrade is nothing brilliant (The Nismo edition doesn't even have that) & can be easilly bettered buying aftermarket rotors/calipers. Essentially aftermarket gear that is 10 or so years further on in its development will always be a better bet than the Nissan/Nismo upgrades offered from the 1990's.
Best way to get your hands on a GT-R that goes harder than a stockie is to buy one already in Australia. The only ones coming in from Japan from now on will be basically stock as per the RAWS scheme.
Just bought a 93 Vspec
Differences:
- Brembos, solid rotors (not cross drilled)
- The diff on R32 GTR Vspec are not finned, the normal GTR is finned (opposite of R33)
- 4WD system is the same same as R33, doesn't take as long to shift touque to the front wheels
- 17" BBS rims (stock)
Suspension is the same.
Thats about it. Oh, and it has a VSPEC sticker on the back :P
post-27256-1142069595.jpgthanks gexenon, and everyone else btw, but i think i'm leaning toward a Nismo edition, or at least one with the body kit, they just look f*@#in' sweet.
is it just me or does that screen shot say they have bigger turbos???
what does everyone think about what level of mods/tune to buy?
should i get a stocker or mild modded? because they would both have had a hard life, the modded one might have had a little more money spent keeping everything in order?
i don't know, does anyone have any comments/suggestions from experiance???
    • Pads for R32 GTS-t, R32 GT-R non V-Spec (Sumitomo), R33 GTS-t and R34 GT-t are all interchangeable. R34 GT uses a 2x piston caliper, hence it didn't fit.
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
