I went for a drive last night, and ended in North Sydney and came to a set of lights.
Anyways a Red Mitsubishi 3000GT pulled up behind me, and then reversed and came on my left, and i thought alright your on, so im waiting for the lights to change, and i see the opposite lights turn orange and then red, and then our lights turned green and i hit it, by second gear i was wondering where is he?
He did'nt even go for it and peacefully came back into my lane there was a car parked.
DAM i wanted to drag a 3000 GT does any know how fast they are? or even had a go with one? would be interesting to find out not that many around.
https://www.sau.com.au/forums/topic/1092-3000gt-vs-skyline/
the aussie delivered 3000GT's arn't turbo (i dont think) - they should be similar to the aussie delivered Z's... ie, big and no power.
The GTO's on the other hand are TT etc...
i *think* thats how it is anyway... not 100% certain.
https://www.sau.com.au/forums/topic/1092-3000gt-vs-skyline/#findComment-22585
funny you should mention that....
the LATE model 97+ versions are 320hp..... using the mitsubishi 6g72TT engine....
my sonata came with a 3.0L V6 option (only in auto) and guess the engine code... 6g72 (no TT here!)
The Twin Turbo V6 engine from the 3000gt/GTO's would fit straight in my sonata....
think of this kind of power in say a 1200kg car (FWD!)
.....*sigh* I done the research.. AND, to possibly have the world's fastest Sonata I would be looking at about $10,000 for the front cut, new ECU, labour, parts etc....
.... but then, I've always wanted a Skyline, so I decided not to piss my money away.
Think I made the right decision ??
https://www.sau.com.au/forums/topic/1092-3000gt-vs-skyline/#findComment-23229
Guest Cinder
Only Twin turbos were sold here, you have to import the N/A version. A GTO/3kGT should beat a GTST easy they run 13.3-5 with a decent driver some have been known to hit 13.0 stock. The fastest GTO is the MR it's the sports version they come with harder suspension and BBS rims and have less options then the GTO TT, they run 12.8 stock but i dont think any of them are in australia.
That said stock for stock with equal drivers it goes like this
1: GTO MR 12.8
2: GTR 32-34-33 13.0-1-2
3: GTO TT 2nd GEN 13.3-4
4: GTO TT 1st GEN 13.5-6
https://www.sau.com.au/forums/topic/1092-3000gt-vs-skyline/#findComment-24336
Guest Cinder
There might be an MR in aus but i have never seen one. I was going to get an MR but it has no leather or active aero dynamics or AWS or climate control and a bunch of other goodies that the higher model GTO has. I might still get an MR just depends what i run into over in Japan i also might be getting an R33 GTR as a daily driver/fast car, because i will be moding the GTO like crazy.
https://www.sau.com.au/forums/topic/1092-3000gt-vs-skyline/#findComment-24429
Originally posted by DLuded
Onarun:
a shelby gt500??
off gone in 60 seconds?? the 1967 one..i LOVE that car
that be the one. i've been in love with it ever since my days of 'street rod'
remember that game where you'd drag cars for pink slips? spent hours playing that game.
in around a years time i'll have a double garage and i'll be looking for a cheap one to restore. will be very hard to find in aus so i'll have to import it from usa i think.
https://www.sau.com.au/forums/topic/1092-3000gt-vs-skyline/#findComment-24642
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
