Geez I go off for a couple of weeks and already the children are not playing well together.
The reason why a twin plate was decided on was because John expressed to me the need to have his clutch hold 300-350kw at the wheels and he didn't want a button single plate. A single plate organic will not handle 300rwkw so the choice is fairly clear.
Twin plate clutches ALL use button style plates but the paddle style button configuration was chosen for lightweight instead of the heavier full plate. The buttons are also rivetted on instead of sprayed on and the cost to overhaul this particular one is about 1/3 of the cost of the exedy hyper twin.
The Exedy hyper twin puts too much load on the crank plate, wears out the carrier and the pedal is three times heavier. This clutch has the same light feel as a stock SR20 clutch and will hold 1000hp at the wheels. It does not drive anywhere near as harsh as single button clutch.
Yes it does grab hard but you can ride it so it drives a lot easier than the button singles.
If you have never owned or installed a twin plate then please look but keep the uneducated comments to yourself. A lot of time went into the development of this clutch and it is by far the best one on the market. Anyone who owns a car with near 300rwkw will know that a single plate is a waste of time and will understand the choice. If you are one of these people then maybe you should ask John to take you for a drive and I'll guarantee you will be impressed with not only the drivability but also the pedal feel.
Edited by 3lit3 32
  • Replies 95
Dan thanks for the PROPER explanation regarding choice.
But seeing as I HAVE installed these before and HAVE driven cars with these in them, depending on friction compounds, they can be a bitch.
So I guess the uneducated comments were not addressed to me...lucky....
On a side note how come not a sprung centre plate, these would still provide enough friction and clamping but without the overall harshness and vibration that inherently accompanies an unsprung centre!!! I agree with why the button and not the full face, however, clamping pressure is greater using buttons than full face, so having it being not as heavy I find a little bit hard to swallow, that being said I am happy to be proven wrong. Also the rivets are always better to overhaul...I think they are the bee's knees when it comes to replacing!!!
I can see why multiplate has been the choice here, single plate, either button or otherwise will not hold 300rwkw...well it will but not for long...
Edited by Bobjones
I was wondering if you were gonna come back dan and explain to everyone...
Good on ya...
I had a single plate button in my GTS-X and it could slip quite a bit once you got used to it... Most would jump straight in and stall the car...
Brisbane Tunning in woolloongabba, was done this morning.
The injectors will be upgraded within the next week or so.
Just going to look around for what would be best. Was recommended to go more then 550cc but less then 650cc.
Coilpack will also be replaced as coilpack 4, 5, 6 aren't all that good.
550's will do what you need but they will be up around 90% duty I would think. The next step up from them are the 650's but I wouldn't go over that. I've gotta re-check my HKS injector prices and I'll let you know John. There is only 3 Sard's left from my supplier and it won't be for a while until they have more.
Nismo and most other only offer 550 or 740 direct drop in, unless you are going to change the rail...
Good result though so post up a sheet!!!
i`ll post up dyno sheet tomorrow.
i left the sheet here at home when i got back from brisbane tunning.
so i`ll take it into work tomorrow and scan it and then post it up here.
    • Just had this happen to me too.  R32 GTR.   Also broke "just before going out onto the track" - someone up there is looking out for us... Very scary since I was about to do a narrow street course with zero run-off and curbs everywhere. Many people on here upgrading to billet uprights and R35 bearings?   Or buying new OEM knuckles?  I am not keen to replace with another s/h 30 year old fatigued part.
    • Top off with distilled water and see what happens. If you keep losing coolant then you know to start looking.
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
